20 Most Recent Toshiba 36HF12 TV Questions & Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Toshiba 36HF12... | Answered on Jan 17, 2015
This is a classic indicator of bad solder connections on the main board, if you are handy with a soldering iron unplug set, remove back and tilt board up to access the printed circuits, resolder all flyback pins and surrounding areas in the high voltage area.
Toshiba 36HF12... | Answered on Jan 05, 2012
Hi.
Here the full service manual. Click on the link below to open the manual. The file is big. If the page does not load, stop the page that is loading in browser, click the right button of mouse on the link, then open the manual.
SERVICE MANUAL CH:N2PF
Toshiba 36HF12... | Answered on Feb 24, 2011
The TV does need a converter box to receive digital off-the-air broadcasts. It's an HD set, but that doesn't mean digital; no digital tuner was built in. You can find the manual here at Toshiba. Hope this helps, and thanks for using Fixya!
Toshiba 36HF12... | Answered on Feb 18, 2010
If you provide model and chassis number, we will provide you with more detail info.
The IR sensor could be defective if It does not respond to any remote control.
Toshiba 36HF12... | Answered on Apr 05, 2008
Things are not so simple. Your universal remote control may not be compatible. Use code search to find out. All URCs do not contain all possible codes for all devices.
Toshiba... | Answered 10 hours ago
Use code search.
Toshiba... | Answered on Jul 26, 2020
The TV's main culprits to be causing this problem are "dynamic contrast" which maybe darkening the backl light in dark scenes an example a night time or a dark scene in a movie. To make the blacks be deeper (as LCD/LED TV are rubbish at blacks) or brighten it on bright scenes to make the light be lighter and once again to make the blacks be deeper so the images pop out. Also "eco lighting" this will dim or brighten the image based on the amount of light in a room in order to be saving energy. Ether way the easy fix is to turn both of these features off. You will get rid of the problem and enjoy more subtler shades of colour that would otherwise be bleached (brightend) or crushed(darkend) out..
Toshiba... | Answered on Jul 22, 2020
the pin code for your Toshiba tv is 0000
Toshiba... | Answered on Jul 15, 2020
Try this. It might work or it might not
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Toshiba... | Answered on Jul 10, 2020
You will have to disassemble the unit to get access to and remove the stuck tape. Keep track of the disassembly process for reassembly with no parts left over.
Toshiba... | Answered on Jul 04, 2020
Use code search on the URC to find something that works. If a search through all codes stored in your One for All fails, try a different URC. All URCs do not contain all possible codes.
The trouble with the video cassette recorder is it is full of rubber components - belts and wheels that don't age well, though it is doubtful that is the only problem.
Capacitors too, often don't age well, especially if the unit could have been subjected to high summer temperatures or freezing winter temperatures but again that probably wouldn't render the machine completely unresponsive.
It should be possible to remove the top cover of a front loader and turn the mechanism by hand to remove the tape but putting it back into working order should be left to a professional. There is often an internal fuse and it could be worth checking that...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Toshiba... | Answered on Jul 01, 2020
Your repair guy is right. An 86" Samsung LED is the way to go.
65HM167 Toshiba Replacement Parts - Encompass
toshiba.encompass.com > model > TBA65HM167
65HM167 Toshiba Lcd/dlp Projection Tv ' Encompass replacement parts & accessories. ... Category, Part Number, Description, Demand, Availability ... Toshiba 75006636, Toshiba Owners Manual, Ships in 14 days 51.39. Add to Cart.
Parts List - Toshiba 65HM167 - 65" Rear Projection TV ...
www.manualslib.com > ... > Service manual
Toshiba 65HM167 - 65'' Rear Projection TV Manual Online: Parts List. Location Part No. Description A026 75004854 REAR VENT ASSY A100 75006662 ...
Toshiba 65HM167 Parts & Accessories List - TVserviceParts ...
www.tvserviceparts.com > Toshiba-65HM167-Parts-List
Toshiba 65HM167. Find the Power Supply, Main Board, Motherboard, T-Con, Remote Control, Power Cord and a complete list of parts & accessories for your ...
toshiba 65HM167 Parts and Accessories - PacParts
www.pacparts.com > model > model_id=65HM167 > action=list_part
Mfg / Part No, Description, Availability, Price, QTY. Toshiba 75008204, Lamp Y67-LMP, SEE SUBSTITUTE. Replacement Available - See Below. Replacement ...
Toshiba 65HM167 television parts ' Sears Parts Direct
www.searspartsdirect.com > model > toshiba-65hm167-television-parts
Toshiba 65HM167 dlp television repair and replacement parts. Search parts in this model. Go. Click a parts diagram below to narrow your scope. All parts.
Toshiba... | Answered on Jun 16, 2020
We neither sell or supply any goods.Try fleabay or Alibaba etc
Toshiba... | Answered on Jun 02, 2020
Toshiba 36HF12 TV Logo
Popular Tags
7 questions posted
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
blind tv
  • Televison & Video
