20 Most Recent ViewSonic GA771 Monitor Questions & Answers
Double click the clock time on the bottom right of the screen. Make sure that you are set to the right time zone and make sure that the Show Daylight Savings Time box is checked.
ViewSonic GA771... | Answered on Dec 05, 2013
what type of mouse is this? track ball or laser? if its track ball try to remove the ball and clean it with soap and water, there is two gear inside the mouse one for vertical the other for horizontal movement the rod of these gears sometimes get covered with dirt which cause the erratic movement clean this with light alcohol and all will be ok
ViewSonic GA771... | Answered on Dec 03, 2013
if it is a ball track mouse, the re is lint inside and it needs to be taken apart and cleaned. If it is a wireless mouse, there is either a solid object where it looses the signal for a bit every once in a while, or the batteries are low. Your processor could be too busy with trojans or keyloggers... just in case get spynomore free to try off the internet and run a smart scan and see what it finds.
u place your speaker near the monitor or any magnetic type devices so keep it away.still if u have pbm check your picture tube or lcd screen
ViewSonic GA771... | Answered on Nov 25, 2009
you should run memtest on it and make sure your memory is good sounds like it could be bad memory please test this and get back to me with the results Thanks 8^)
ViewSonic GA771... | Answered on Nov 09, 2009
first check loseconection and tube light and nearaset spk for sparking .and check the earth of monitor main waire
ViewSonic GA771... | Answered on Nov 18, 2007
This is a hazard that you need to figure out. First thing is to check the power cables, Some of those monitors use a separate power brick and some dont. IF yours has a power brick, make sure it is made by viewsonic. It maybe a polarization issue with the wrong power unit. If the monitor plugs straight into the power cord and then into the outlet, check the cord ends to see if they are polarized ( one is bigger than the other spade) If they are different sizes where they plug into the wall, there is something more serious wrong inside the unit. You should use an electric meter to see how high the voltage is. IF it is more than 50 Volts you should stop using the unit. That model number is not listed on Viewsonics website. There is one that is close but they are not making it any longer.
ViewSonic... | Answered on Apr 05, 2020
https://support.viewsonic.com/en/support/solutions/articles/33000221575-what-to-do-when-no-display-from-my-monitor-
ViewSonic... | Answered on Apr 04, 2020
Test the switch for continuity in the open and closed position. Sometimes defective switches function mechanically but not electrically.
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds.
http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
https://www.youtube.com/watch?v=X6Tn6a_Xy7Y
https://www.youtube.com/watch?v=-EfwZnWYrvI
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets
I hope you can disarm it, comment the results
Greetings Franco Dosil
Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas
Espero que puedas desarmarlo, comenta los resultados
Saludos Franco Dosil
http://www.viewsonicglobal.com/public/products_download/36/29622.pdf
http://www.viewsonicglobal.com/public/products_download/36/29639.pdf
ViewSonic... | Answered on May 13, 2019
As long as they are the same value
ViewSonic... | Answered on Apr 18, 2019
The problem is seems to be in power supply section. it may be need to repair by electronic technician, after using any monitor 5 to10 years there may be power section or lcd panel may be damage.
ViewSonic... | Answered on Jan 30, 2019
It is more likely to be a problem with your video card or on-board video. The only way to check is to connect the monitor to a laptop or another computer known to work.
ViewSonic VE710b VE710 17 LCD Display LED Display
ViewSonic... | Answered on Dec 30, 2018
no PC stated. no OS stated, so... weak answers... next.
actually only old windows did that!
once it needs to do that, that means the HDD shows errors.
they are not ever supposed to show errors
and in fact self repair them selves (2001 to now HDD)
what I do is shut the PC off.
them test the hDD as remote disk and run smart tests
or
boot the same PC with say linux demo disk (or usb stick)
and RUN SMART test.
if the fail the HDD is no good. hopeless cases.
the next actions is backup data.
the PC you have running silly old chkdsk
will actually damage more data doing that,
that is why w10 does not do that, it just tells you
smart fails on HDD0 or the like.
Just 2 steps of you have the linux media pre made.
as all techs do.
no PC stated and viewsonic is not a PC.
boot to linux, click try me, then run disktest
if it fails smart tests the hdd is bad.
http://pcdied.com/linux.html
ViewSonic... | Answered on Dec 22, 2018
so you want to open the va1928 case.
did you take off the stand and full remove the stand mount first.
and see screws hidden there, did you remove all screws on the back first?
the mount is steel and has 4 screws , off those first.
the book is free to read, users guide
page 10, says wall mount
this 1 page shows,
1: remove the snap off lastic panel first. that normally hide cables on rear, or just hides the steel mount.
and the magic 4 screws on it. then pry it.
steps 1 to 4, page 10
https://www.manualslib.com/manual/266493/Viewsonic-Va1926w.html?page=10#manual
then remove all other screws you see and it comes apart.
this is close, nice clear english too. refreshing.
https://www.youtube.com/watch?v=UJuMdIUQ_k8
the pr ytools are; in order of best to worst are.
1: using std, cell phone pry tools.
2: using a Guitar pick,
3: wreck your CC , us an old useless credit card.
4: now use screwdriver an mangle the edges for "art"
5: claw hammer it? or a finely sharpened crow bar?
ViewSonic GA771 Monitor Logo
10 questions posted
Top ViewSonic Computers & Internet Experts
Ekse
Dimitar Todorov
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
fujitsu lifebook n series laptop
  • Computers & Internet
