20 Most Recent ViewSonic VA902b 19" Monitor Questions & Answers
Monitor doesn't display color correctly. My
Your display panel needs replaced
6/26/2017 1:08:30 AM • ViewSonic VA902b... • Answered on Jun 26, 2017
5answers
Screen won't stay on
This is a common problem with LCD monitors after a few years of use. The capacitors in the power supply board start to fail and this prevents the monitor from starting up correctly. Sometimes you get a picture and then it goes black. On some units you can keep pressing the power button and after several power up cycles the monitor will work until you turn if off. These symptoms are all common with capacitor failure. The monitors are well out of warranty now so Viewsonic will not cover the repair cost. But the repair is very easy to do yourself. You just have to replace the 6 power filter capacitors on the power supply board. Here is a link to additional information on this repair.http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218I hope this helps, I have repaired over 30 of this model with the same issue.
6/21/2012 3:53:49 PM • ViewSonic VA902b... • Answered on Jun 21, 2012
2answers
When I turn on my ViewSonic VA902b it flashes the
The problem can be in the backlight inverter circuits, look fo bad caps with bulging tops, look to see if you do have 12vdc feeding the inverter circuits. See some examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
6/21/2012 3:32:51 PM • ViewSonic VA902b... • Answered on Jun 21, 2012
Are there speakers on this monitor
No, http://www.newegg.com/Product/Product.aspx?Item=N82E16824116363
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
2/10/2011 6:00:12 PM • ViewSonic VA902b... • Answered on Feb 10, 2011
When I turn on my monitor it turns of a second
Look for bad caps with domed tops, similar to the 17" model:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA702b_s/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/10/2011 5:58:08 PM • ViewSonic VA902b... • Answered on Feb 10, 2011
I get "Out of Range" message. What is this?
The monitor resolution settings has been changed.
please set the resolution settings to defaults in the monitor
1/27/2011 3:35:30 PM • ViewSonic VA902b... • Answered on Jan 27, 2011
Monitor shows windows desktop at startup then
Look for bad caps with leaking/bulging tops first.
It is similar to 702b: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA702b_s/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
1/4/2011 10:53:17 PM • ViewSonic VA902b... • Answered on Jan 04, 2011
Turns on and shuts off automatically 3 seconds
Look for bad caps, see VA702B album, it is the smaller version of the VA902B.
12/13/2010 4:03:03 AM • ViewSonic VA902b... • Answered on Dec 13, 2010
Won't turn on rightaway
I would look for bad caps with leaking/bulging tops or seals. 702 is similar to 902
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
11/22/2010 2:35:45 AM • ViewSonic VA902b... • Answered on Nov 22, 2010
Turned monitor off with the on off button and when
If you are going to DIY and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement board: http://www.lcdrepair.us
11/10/2010 11:40:02 PM • ViewSonic VA902b... • Answered on Nov 10, 2010
When the display is turn on show for a few seconf
Look for bad caps.
http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
9/28/2010 3:58:29 AM • ViewSonic VA902b... • Answered on Sep 28, 2010
Moniter flashes on whenstarting, but
More likley to have failed DC filter caps problem, but you should try it with another PC first.
9/23/2010 5:06:16 PM • ViewSonic VA902b... • Answered on Sep 23, 2010
Acts like a faulty cap it turns on and then a
Yes, very likely to be bad caps:<br /> <a href="http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA903B/">http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA903B/</a><br /> <br /> Just like all other failed VIEWSONIC and all other monitors as shown in my albums.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <a href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><span style="mso-spacerun: yes"> </span>http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
8/26/2010 8:29:23 PM • ViewSonic VA902b... • Answered on Aug 26, 2010
The monitor is blinking picture unclear
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
5/17/2010 9:52:38 PM • ViewSonic VA902b... • Answered on May 17, 2010
I have a VA902B Viewsonic 19 inch lcd. When I
power supply on your monitor is not stable. Could be 1 of the ballast transformer of the backlight in the monitor is overheating and soon to burn out, that cause the instability of the power supply.
5/17/2010 8:00:30 PM • ViewSonic VA902b... • Answered on May 17, 2010
2answers
I am trying to set up my Viewsonic VA902b as a
yes.....you need to install the driver for the AGP card from which you will connect the second monitor....
4/28/2010 11:16:58 PM • ViewSonic VA902b... • Answered on Apr 28, 2010
How to get the power supply out of the viewsonic
Please look at my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VE710B/
It is alomost the same as 902.
Mkae sure to use good caps such as PANASONIC FM or FC series from DIGIKEY.
4/22/2010 3:19:32 AM • ViewSonic VA902b... • Answered on Apr 22, 2010
ViewSonic VA902b 19" Monitor Logo
37 questions posted
Top ViewSonic Computers & Internet Experts
Steve
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
when turn viewsonic va902b flashes
  • Computers & Internet
