20 Most Recent ViewSonic VA1912wb 19" LCD Monitor Questions & Answers
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
ViewSonic... | Answered on Nov 09, 2015
i think your monitor is going to expired soon , i u have valid warranty then try to contact service center if not then buy a new one LED monitor is best than LCD and LED has more life expectancy and woks very well so bye t.c
ViewSonic... | Answered on Aug 21, 2014
On some monitors you have to select the source your wish to view via the monitors menu. Good luck
ViewSonic... | Answered on Oct 14, 2013
depends on the connections on the monitor/tv. you can get conversion cables like hdmi to usb for example.
ViewSonic... | Answered on Jul 31, 2013
check the lead from the monitor to the connection on your computer
ViewSonic... | Answered on Oct 04, 2012
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
ViewSonic... | Answered on May 20, 2011
Hi There and Welcome to Fixya.
Horizontal or vertical lines flashing/running across the screen poses serious display issues with any LCD/CRT monitors. It only boils down to 2 possible causes :
  • Corrupted video driver
  • Hardware issue
To help you determine which of the above, here's what you need to do.
  • Ensure that the computer is turned OFF
  • Disconnect ALL USB devices except the keyboard
  • Turn the computer on and immediately hit "DEL" (in some systems, it's the "F2") key repeatedly until you reach a different screen. (not the usual Windows screen)
  • Welcome to the BIOS screen
  • From here, spend 30min to 1 hour observing if the lines are present in this mode
If you still see the horizontal lines, then there's a need for the monitor to be serviced by a certified/trained technician. The link below will direct you to their support page for repair/replacement options, depending on your warranty status :
ViewSonic Support
Otherwise, the problem can be resolved by re-installing the operating system.
I hope this helps, Thanks for using Fixya.
ViewSonic... | Answered on Apr 09, 2011
Hi. The only information that could be of any help to you is as follows..
http://www.moniserv.com/doc/pricelist.html
www.abnet.am/images/Viewsonic_va1912w.pdf
The answer to question 2 is No. The crack will have no effect on other components. Hope this is of some use to you.
ViewSonic... | Answered on Feb 16, 2011
Hi, Here is what I was able to find out about your monitor from ViewSonic. There is no manual available on their website.
I have two ViewSonic monitors that are very similar to the one you have.
Here is what I can tell you. The monitor, although it does not seem like it can, be tilted front to back.
If you grip the monitor screen on the side edges (left and right) and 1/3rd the way up and twist it either away or toward you, it should tilt. It is a little stiff, just go ahead and tilt it. As far as adjusting the high. That, I'm sorry to say cannot be done.
I hope this helps you.
Best Regards,
Mark
ViewSonic... | Answered on Feb 15, 2011
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
ViewSonic... | Answered on Jan 30, 2011
Use the Stereo mini audio line in cable to connect it from the computers audio output - colored usually light green.
ViewSonic... | Answered on Jan 22, 2011
It depends on the operating system. In WinXp right click on a free spase at your desktop > properties > settings > resolution bar
Stelios.
ViewSonic... | Answered on Jan 19, 2011
More likely to have bad DC filter caps with leaking/bulging tops just like the failed VIEWSONIC as shown in my albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
ViewSonic... | Answered on Dec 30, 2010
Look for bad caps first.
ViewSonic... | Answered on Dec 24, 2010
ViewSonic VA1912wb 19" LCD Monitor Logo
75 questions posted
Top ViewSonic Computers & Internet Experts
Ekse
Alun Cox
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Computers & Internet
Most Popular Question
adjust screen tilt
  • Computers & Internet
