20 Most Recent Maytag MEW6530DDS Stainless Steel Electric Single Oven Questions & Answers
You may have a bad heater coil in the oven or have lost a leg in the 220 line. Check and reset the breaker 1st then check the voltage in the receptacle. It should be 110 from each leg to ground and 220 across the hot legs.
Maytag... | Answered on Jan 04, 2015
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Maytag... | Answered on Apr 16, 2014
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Maytag... | Answered on Jan 26, 2012
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Maytag... | Answered on Jul 13, 2011
Hello, Thank You for using FixYa. I will be helping you today. Pull the oven out a few inches turn the power off. You will see two screws on each side of the control when you pull it out remove them. Then take off the control panel you will see the high limit about mid way back. Thats it..
Maytag... | Answered on Jun 21, 2011
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Maytag... | Answered on Jun 10, 2011
Check out www.appliancepartssolutions.com for a good price on your control board.Have the part# available you need or click on their "live chat" feature for help.
Maytag... | Answered on Nov 08, 2010
Unfortunately your going to have to call a service tech out, unless you have a programming manual.
Maytag... | Answered on Oct 10, 2010
Go to the cumputer settings on you cumputer an turn it on the tuch pad
Maytag... | Answered on Dec 15, 2009
Hello could be oven thermostat,when you are sure of the part you need check out www.appliancepartssolutions.com cheep parts!
good luck
Maytag... | Answered on Nov 18, 2009
for an inexpensive board check out www.appliancepartssolutions.com
you will need the part# or click on chat for assistance.
Maytag MEW6530DDS Stainless Steel Electric Single Oven Logo
28 questions posted
Top Maytag Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
oven slow heat up will not heat above
  • Ovens
