20 Most Recent
Xerox Phaser 7400/DX Laser Printer Questions & Answers
Phaser 7400 14: real time clock
According to my service manual, this error is occurring during the Power On Self-Test. While it is a "soft" error, it normally can only be resolved by replacing the Image Processor Board.
But wait! There's more!
Here may be a way to reset without the expensive replacement:
The most likely cause is that the Image Processor Board has not successfully loaded
its NVRAM contents (instructions) into RAM. All print engine operation halts, and
will only become ready when the Image Processor Board successfully boots.
1. Check for media or debris in the paper path.
2. Power cycle the printer.
3. Verifying Image Processor Board failure:
a. Power-off the printer, and remove the Image Processor Board.
b. Power-on the printer. Wait at least 5 minutes while the print engine
initializes. If there was a problem with the Image Processor Board, it will
now not affect the Engine Control Board.
c. If characters appear on the Control Panel display, the Engine Control Board
is functional and the problem is most likely with the Image Processor Board.
d. Turn off the printer and reseat the Image Processor Board and turn on the
printer to determine if seating was the problem.
e. Perform a PostScript NVRAM reset, see "Postscript NVRAM Reset" on
page 6-9.
f. Turn off the printer and systematically remove individual optional
components from the Image Processor Board to isolate a possible problem
component.
g. Replace the Image Processor Board.
I wish you luck with this repair.
Phaser 7400 squeaks while printing
id try lubing the feed rollers well the metal bars where they contact the chassis and lube gears and stepper motors. its been awhile since ive had my phazer. i traded it last year to my church pastor but try that. radio shack sells a teflon lubricator part no. 64-2301a and im certain amazon also sells them. ONE drop goes a LONG way. its also a miracle worker for pc fans, and household appliances as well as automotive where its not high heat. even bearings.hope this helps you a tad sorry i cant be more of a help here but thought id pass a few personal experience in fixing electronics/mechanical tips along.
