20 Most Recent Zebra Eltron P520i Dual Sided Printer Questions & Answers
P520i vista drivers
Did you try installing the XP drivers in Vista using the Vista compatibility mode?
Another option to use XP drivers in Vista involves changing the group policies.
Hope one of them works for you!
8/29/2009 10:29:43 AM • Zebra Eltron... • Answered on Aug 29, 2009
My printer Eltron P240 is not compactible to windows 7. please what do i do?
Go to www.bartenderbarcodesoftware.com and download a new driver.
12/9/2013 11:24:17 AM • Zebra Eltron... • Answered on Dec 09, 2013
0answers
Zebra printer. How to print serial numbers with a code in sequence on it?
Question edited for clarity. Duplicate question deleted. Refresh page to see your question.
Zebra Printer Serial Number Structure
Zebra Support Community https://supportcommunity.zebra.com > article > Zebra-... May 9, 2019 - Zebra Printer Serial Number Structure ; XX - Product Reference (usually 2 but can be 3 or 4 digits) ; A - Place of manufacture ; YY - Year of ...
Generate serial number in zebra printer embed gene...
SAP Community https://community.sap.com > technology-q-a > qaq-p Apr 1, 2017 - How to generate serial number in zebra printer ('^XA^SN001,1,Y^FS^XZ') from a Smart form and also embed generated serial number in QR Code? We ...
How to print barcode with running number ZPL-II?
Stack Overflow https://stackoverflow.com > questions > how-to-print-... Dec 5, 2008 - Try changing the ^PQ2,0,1,N to ^PQ2,0,0,N . The value in in replicates field indicated that you wanted a duplicate serial number printed before ... 6 answers ยท 1 vote: Ripped from a ZPL II manual: ^AF^SN 0001, 1, Y^FS Define serialized field, starting value ... I want to print an incremental count on the top right corner of ... Jul 14, 2020 C# - Printed serial numbers using Zebra printer is not scanning Jul 20, 2016 Zebra ZPL code Repeat label X times - Stack Overflow Aug 10, 2017 Create unique serial with ZPL and RFID - Stack Overflow Aug 21, 2023 More results from stackoverflow.com ..
2/15/2024 7:16:44 PM • Zebra Office... • Answered on Feb 15, 2024
Zebra GX420t Label Printer wont calibrate?
It appears to be a well documented issue. Try the Zebra Support Forum. https://www.google.com/search?q=zebra+gx430T+wont+calibrate ..
12/15/2023 1:55:40 AM • Zebra Office... • Answered on Dec 15, 2023
2answers
My Zebra P120i will no longer print correctly
8/9/2023 6:56:58 PM • Zebra Office... • Answered on Aug 09, 2023
Zebra LP 2844 printing off center
If your Zebra LP 2844 printer is experiencing shifting or off-center printing, there are a few possible causes and troubleshooting steps you can try:
  1. Check print settings: Ensure that the print settings on your computer or label design software are correctly configured for the label size and layout you are using. Make sure the label dimensions and print margins are set accurately.
  2. Calibrate the printer: Perform a calibration on the printer to ensure it is properly aligned. To calibrate the Zebra LP 2844, follow these steps: a. Turn off the printer. b. Hold down the feed button. c. While holding the feed button, turn on the printer. d. Release the feed button once the green status light begins to flash. e. The printer will feed labels and automatically adjust the label alignment. f. Once the printer stops feeding labels, the calibration is complete.
  3. Adjust label position sensors: The LP 2844 has label position sensors that detect the start of each label. If these sensors are misaligned or dirty, it can cause shifting or off-center printing. Clean the sensors using a lint-free cloth and ensure they are properly aligned.
  4. Check label alignment: Ensure that the labels are loaded correctly and aligned properly in the printer. Make sure they are inserted straight and centered in the label guides.
  5. Inspect the print head: Check the print head for any debris, adhesive residue, or damage. Clean the print head with isopropyl alcohol and a cotton swab if necessary. A dirty or damaged print head can affect print quality and alignment.
  6. Update or reinstall printer drivers: Ensure that you have the latest printer drivers installed on your computer. If the drivers are outdated or corrupted, it can cause printing issues. Visit the Zebra website and download the appropriate drivers for your LP 2844 model.
  7. Test with different labels or ribbons: If the problem persists, try using different labels or ribbons. Sometimes, the issue could be related to the specific media being used.
7/2/2023 2:57:18 PM • Zebra Office... • Answered on Jul 02, 2023
I have a Zebra series 1 that keeps throwing a mecanical error after printer the first pass yellow. It also seems like it is checking the ribbon. When ever I open the card reservior lid.
One possible reason for this issue could be a problem with the printer's ribbon sensor. The ribbon sensor is responsible for detecting the presence of a ribbon and ensuring that it is properly aligned. If the sensor is not functioning correctly, it may cause the printer to throw a mechanical error and check the ribbon whenever the card reservoir lid is opened. Another possible cause of this issue could be a problem with the printer's motor or drive system. If there is an issue with these components, it may cause the printer to stall or throw an error message when attempting to print. To resolve this issue, it may be necessary to perform some troubleshooting steps. First, try cleaning the printer's sensors and rollers to ensure that they are free from debris or dust. Additionally, check to make sure that the ribbon is properly loaded and aligned in the printer. If these steps do not resolve the issue, it may be necessary to contact Zebra technical support for further assistance.
6/21/2023 7:49:01 PM • Zebra Office... • Answered on Jun 21, 2023
2answers
Zebra ZP 450 CTP suddenly printing wrong. Labels are scrunched up and only on top half of page
Hi, Please use your manual to follow the initial set of instructions that you used to setup label printing on your Zebra device. Then, you can run a few test prints to make sure that everything is working properly. Otherwise, you might need a factory reset. Thank you.
3/6/2023 5:48:28 PM • Zebra Office... • Answered on Mar 06, 2023
Hi there! My zebra ZP 505 keeps showing up at "Idle" and I can't seem to get it to print. I've tried resetting, reconfiguring, etc. Any tips?
Shane Braddick here, did you try restarting your network? Assuming its a network printer?
3/6/2023 5:47:55 PM • Zebra Office... • Answered on Mar 06, 2023
Zebra LP 2844-Z permanent IP Resolution how to change
If you are unable to change the IP address of your Zebra LP 2844-Z using the ^default command or Zebra Utilities, and updating the BIOS did not help either, you may need to try a factory reset of the printer. To do this, follow these steps:
  1. Turn off the printer.
  2. Press and hold the feed button on the front of the printer.
  3. While holding the feed button, turn on the printer.
  4. Wait for the status light to turn solid red, and then release the feed button.
  5. The status light will blink green a few times, and then turn solid green.
  6. Press and release the feed button once. The status light will blink red a few times, and then turn solid amber.
  7. Press and release the feed button again. The status light will blink green a few times, and then turn solid green.
The printer should now be reset to its factory settings, including the default IP address of 192.168.168.168. You should now be able to access the printer through this IP address and change the settings as needed.
2/27/2023 8:40:31 AM • Zebra Office... • Answered on Feb 27, 2023
Hi, is there a MacOS version of Zebra's CardStudio available anywhere?
The driver software is separate from the design software. Zebra notes the printers that have Mac OS drivers here: https://supportcommunity.zebra.com/s/article/000013605?language=en_US . Unfortunately, their CardStudio is only available for Windows. (So Boot Camp would be the only way to use the included software with any Mac OS.) A Google search for "Bar Code and ID card creation software for Mac OS" gave me a number of choices. One is an app: https://apps.apple.com/us/app/cardmaster-id-card-maker/id1493877440?mt=12 . I can't judge which application is best for your purpose. These range from free to try to Corporate software packages. I hope this helps. Cindy Wells
12/30/2022 11:42:28 PM • Zebra Office... • Answered on Dec 30, 2022
Zebra 6M Plus Shows "Checking Onboard Flash"
It sounds like there may be an issue with the onboard flash memory on your printer. Try performing a factory reset (hold down the pause and cancel buttons during startup) to see if that clears the problem. If not, you may need to contact Zebra customer support for further assistance.
4/18/2022 2:49:22 PM • Zebra Office... • Answered on Apr 18, 2022
Cannot delete print job queue Zebra S600
hi How do I force a print queue to delete?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px; transform: rotateZ(-180deg);"> You can clear the print queue using commands like this.
  1. Select Start.
  2. Type Command .
  3. Right-click "Command Prompt" and select "Run as administrator".
  4. Type net stop spooler then press "Enter".
  5. Type del %systemroot%\System32\spool\printers\* /Q then press "Enter".
  6. Type net start spooler then press "Enter".
12/6/2021 6:38:54 PM • Zebra Office... • Answered on Dec 06, 2021
Zebra Eltron P520i Dual Sided Printer Logo
3 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Eltron Zebra
  • Eltron Zebra
Most Popular Question
p520i vista drivers
  • Office Equipment & Supplies
