20 Most Recent Zoom (56600000) Router Questions & Answers
You should see a small hole, open out a paper-clip and gently press. You will feel a click.
Hold it for a few seconds until you see the lights flashing on the front.
Some modems require the reset to be pressed while switching on.
This will normally give you a "factory reset". Access details will be on the back of the modem or the manual.
Zoom (56600000)... | Answered on Oct 28, 2017
Report to your ISP.
Your "splitter" may be faulty...
Zoom (56600000)... | Answered on Oct 26, 2017
have you (after securing WiFi) reconnected those by typing passphrase?
Zoom (56600000)... | Answered on Mar 26, 2017
I suggest contacting the manufacturers technical support for the quickest solution.
Zoom (56600000)... | Answered on May 16, 2011
U test your internet speed here!...
Zoom (56600000)... | Answered on Dec 17, 2010
Welcome to Fixya
Hi. As what i understand the MC760 alone can connect to the internet without connecting to the router. This device will act as a modem right away. This is the one of the device where you will put in a simcard to connect to the internet if i am not mistaken. You need to download and install the software of for this device and creat a dial up for your to be able to connect to the internet. Here's the link where you can download the driver and the procedure on how to create Dial up.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Zoom (56600000)... | Answered on Dec 04, 2010
Hi ,
I got your issue , I just need the model number of router router, so that I can give information about the firmware which you can updat it on the router , so that it will help you to fix this issue. Please post the information.
Thanks & Regards,
Prema
Zoom (56600000)... | Answered on Oct 09, 2010
Yes Zoom router is compatibe with zoom modem too. Just configure your zoom router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Zoom (56600000)... | Answered on Aug 16, 2010
1. You will have to reset the router to factory default and run the setup wizard using your set up CD and create a new key.
Set up your laptop on the router using either the MAC address or a new password key.
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Zoom (56600000)... | Answered on Jun 28, 2010
The network key is most likely the password if you like for your wireless internet connection. If this is not your connection, you cant obviously get the network key. If it is your wireless connection, then you will need to reset your wireless router and set it up again with a new password that you can remember
Zoom (56600000)... | Answered on Jun 08, 2010
Here is the link to the PDF file to download and save:
http://www.zoomtel.com/documentation/adsl/5660_UsersGuide_Eng.pdf
Zoom (56600000)... | Answered on May 17, 2010
if u are using a WPA security in ur w/l router , u might have issue connecting ... change it into a WEP security type
Zoom (56600000)... | Answered on Apr 17, 2010
username: Admin
Password : password or blank...
Zoom (56600000)... | Answered on Mar 26, 2010
You need to do a reset to the router hold in the the rest buttons for 30 seconds.Then shut down the pc and try it again.
When it boots up see if there are any errors.
I also want you to go (command prompt) type cmd in the run box and type in just like this
ipconfig /all
see if an ip address comes up
then type in ipconfig /release
wait then type this
ipconfig /renew
Wait till it collects info then restart computer it should resolve after that its a communication error with the router and the pc.
Zoom (56600000)... | Answered on Mar 03, 2010
The default IP address for Zoom routers is 10.0.0.2. If you have everything plugged in correctly then you will be prompted for a username and password to access the Home Gateway realm, these are admin and zoomvoip respectively.
Zoom (56600000)... | Answered on Feb 04, 2010
Just "reset" the router back to the "factory" settings,
by inserting a straightened-out paper-clip into the small hole in the back of the router.
Zoom (56600000)... | Answered on Nov 05, 2009
Your pc might be using a static IP address. Make sure its on automatic. Go to Control Panel, Network Connections. Right-click on Local Area Connection and click Properties. Look for Internet Protocol TCP/IP and double click it. Select Obtain an IP Address Automatically and Obtain DNS Servers Automatically. Click OK all the way out. Also disable any firewall you have like Norton Firewall, McAffe, Zone Alarm and the likes.
Zoom (56600000)... | Answered on Jun 22, 2009
Cathy I have the same make and model maybe I can help. I speak both Tech and Non Tech so stop me if I lose you.
1. Did you go through the set up process of first connecting to your wireless router through the cable provide via your PC/Laptop?
2. Congfiguring your wirless via your browser http://10.0.0.200 ?
Zoom (56600000)... | Answered on Feb 25, 2009
Ummm Not that clear
What router and modem are you using?
Is it DSL Cable Sat?
What virus software are you using?
What computer are you trying to do this on? Also Laptop or Desktop?
Zoom (56600000)... | Answered on Jan 25, 2009
http://www.routerpasswords.com/. its here.Was this solution helpful? Show your Appreciation by rating it.RICHARDM69
Zoom (56600000)... | Answered on Dec 14, 2008
Zoom (56600000) Router Logo
33 questions posted
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
Ekse
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zoom Computers & Internet
Most Popular Question
no connection internet
  • Computers & Internet
