20 Most Recent
Alpine SWR-1222D 12" Type-R Series Subwoofer Car Speaker Questions & Answers
My subwoofer is cutting off. I replaced to fuse on
You are probably running the ohms too low for the amp and its drawing too much current. Consult your amp manual for proper load level capacity and you can wire it accordingly. More then likely its only 4ohm stable bridged and your running it at 2 or less depending on if your subs have single or dual voice coils. Try connecting one pos speaker terminal to the other speaker neg then run the left ofer pos on one speaker and the the left over neg directly to the amp (series) I will raise the ohms (amp makes less power) but should not cut off unless the subs ohm are still to low, if this is the case you need a sub with a higher ohm rating or an amp wiht a lower rating...
Alpine SWR-1222D...
Answered
on Nov 13, 2009
I just picked up a 12
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Alpine SWR-1222D...
Answered
on Sep 15, 2009
Same exact problem
Hello phatjay_31,
It's likely that the sub has been damaged by too much power. The Type R's in both 10" and 12" versions can only handle up to 500 watts RMS. The 15" version can handle up to 750 watts. The Rockford-Fosgate T3000bd1 amp puts out 3000 watts RMS into a 1 ohm load.
I'd check the voice coils. They are probably melted.
Hope this helps.
Alpine SWR-1222D...
Answered
on Jul 22, 2009
Cant wire to mono amp
Hello danielperez9,
There are two options for wiring a single 2ohm DVC subwoofer to a mono amp. The first gives a 1ohm load and should only be used if your amp is stable at 1ohm. The second option results in a 4ohm load and would be OK for most amps. Here are the diagrams:
Hope this helps.
Alpine SWR-1222D...
Answered
on May 08, 2009
How I reset my stereo alpine ine-w940
? 4:49
https://www.youtube.com/watch?v=1wv1LzdUYiM
Sep 5, 2013 - Uploaded by Mx Car Audio
I recently bought the Alpine W940 and the bluetooth that connects to ... A simple reboot at the shop and the ...
www.brandsmartusa.com/pdfs/
manuals/20181335.pdf
sp?ciales, de l'actualit? d'Alpine, et vous aurez une chance de remporter des prix. Gracias por adquirir ... MANUAL DE OPERACI?N .... Listening to the Radio .
www.manualslib.com > ... > INE-W940 > Owner's manual
Alpine Car Audio...
Answered
on Sep 16, 2019
