20 Most Recent
Coby 7" TFT Portable DVD Player Questions & Answers
Where can i get the battery 7100 coby TF in fresno and do they have one ?
Have you already removed the battery? There will be information on it telling you which battery to use as a replacement. As a general rule I would suggest you Don't start taking things apart if you are not sure what you are doing! You could cause more problems than you're trying to fix. Ask at your local TV repair shops and even some of the computer repairers. They may be able to help you. You would have to ask them directly if they have one in stock but commonly if it isn't a commonly used battery they will have to order one in for you.
If you have the battery details you might be able to get one online.
HOW DO I PROGRAM MY COBY UNIVERSAL REMOTE CRC-02
If you don't have the code for your device, you can use the auto search method to find the correct code. Here are the steps:
Turn on the device you want to program.
Press and hold the Setup button on your remote until the LED light turns on.
Press the device button (TV, DVD, CBL, etc.) for the device you want to program.
Press the CH+ or CH- button repeatedly until the device turns off.
Press the Power button to turn the device back on. If it turns on, the remote is programmed successfully.
Otherwise, you need to search for the manual for the remote.
Coby RC-028 under-the-counter television. on local channel 5 the audio is both English and Spanish. How do I turn off the Spanish portion?
If you are hearing both English and Spanish audio on local channel 5 on your Coby RC-028 under-the-counter television, you may need to adjust the language settings. Here are some steps you can try:
- Press the "Menu" button on the remote control.
- Use the arrow buttons to navigate to the "Audio" or "Language" menu.
- Look for an option called "Secondary Audio" or "SAP" (Secondary Audio Program). This option controls the language of the audio.
- If the "SAP" option is set to "Spanish," select the option to change it to "English" or "Off" (depending on your preferences).
- If there is no "SAP" option, look for a language setting or a similar option that may control the audio language.
- Save the changes and exit the menu.
- Test the TV to see if the language has been changed.
If these steps do not resolve the issue, consult the user manual for your Coby RC-028 or contact the manufacturer's customer support for further assistance.
Manual for Coby 224 DVD Player
The manual is all over the internet! Question edited for clarity and move from Office Equipment to the correct one.Coby DVD-224 Manuals ' ManualsLib
www.manualslib.com > ... > Coby Manuals > DVD PlayerCoby DVD-224 User Manual (23 pages) Table of Contents. About DVD. About MP3. About the Player. Front Panel. Rear Panel. Remote Control. Getting Started. Problem Disc Message. Power Management. DVD Mode.COBY DVD 224 USER MANUAL Pdf Download ' ManualsLib
www.manualslib.com > ... > DVD Player > DVD-224View and Download Coby DVD 224 user manual online. dvd/cd/mp3 player. DVD 224 dvd player pdf manual download.COBY electronic DVD Player 224 User Guide ' ManualsOnline ...
tv.manualsonline.com > manuals > mfg > 224COBY electronic 224 DVD Player User Manual · 1) Press the "Setup" button. · 2) On the "Down" arrow, press it three times. · 3) On the "Right' arrow, press it once. · 4) ...
