20 Most Recent Hitachi Deskstar 7K500 500 GB Hard Drive Questions & Answers
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Hitachi Deskstar... • Answered on Jan 20, 2014
IDE and ATA are synonymous to one another for the most part. It will work. Jason
Hitachi Deskstar... • Answered on Feb 08, 2013
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer then defragment your hard drive hope this helps
Hitachi Deskstar... • Answered on Mar 28, 2011
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Hitachi Deskstar... • Answered on Jan 29, 2011
Is it an external or an internal disk-drive?
What have you tried?
What error-messages did you get?
Hitachi Deskstar... • Answered on Nov 21, 2010
First test your CPU then tast all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Hitachi Deskstar... • Answered on Nov 03, 2010
Making multiple assumptions...
You may want to try and take the bread-board off the back of the drive and try re-seating it to the chassis. Luck being a lady you may have just misaligned one of the pins going to the disk drive platters, but I wouldn't put much faith in this trick as most of these boards are matched up within an n'th of a degree and just short of a nuclear blast could knock them that far out of alignment.
The other would be to find a drive of the exact (or close as humanly possible) drive, take the back off of it and see whether or not that sparks the life back into the drive long enough to get your information off of it. Again, this might be a long shot as well.
Sadly, the only other possibility would be that the read/write heads had jumped off of the platters so far that they may be holding the disks down and no ammount of anything will get them seated back to their proper place. Unless you want to drop between $1200 and $1800 to get the data off without further physical damage to the platters.
Hope it helped, but probably not the exact answer you wanted to hear...
Hitachi Deskstar... • Answered on Oct 25, 2010
Make SURE you dont' have any data on the drive that is important (or you have a good back up) Click "COmputers" and "manage" you will need to initialize the drive for VIsta to recognize it.
Hitachi Deskstar... • Answered on Jul 23, 2010
What service pack are you running? Does your bios support the drive?
This would be a bios limitation. Formatting wont' fix the issue. Check your bios and see if it supports "lba" . Certain manufacturers offer "Drive overlay" which will allow you to use the space ..
Send it to me. http://techrxgb.com TechRx, Inc. of Wisconsin. Data Recovery company. Offering free estimates. We have specific tools that emulate the pcb's of hitachi and makes for simple recovery of your data.
Narros it down to the hard drive being dead.
Hitachi Deskstar... • Answered on Apr 17, 2010
If the noise is like a repetitive ticking or clicking. Well, the sorry to say that the hard drive had crashed... which makes the noise... And sorry to tell you that you cannot do anything but to buy another...
sorry... Fixya!!!
Hitachi Deskstar... • Answered on May 21, 2009
Update your ms Drivers and Service pack.
Hitachi Deskstar... • Answered on Jan 27, 2014
Hitachi Deskstar 7K500 500 GB Hard Drive Logo
Popular Tags
26 questions posted
Top Hitachi Computers & Internet Experts
Davit Mamyan
Davit Mamyan
Michael Thomas
Michael Thomas
Dennis Boxerman
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Deskstar Hitachi
  • Deskstar Hitachi
Most Popular Question
after seeing windows logo takes 10mins
  • Computers & Internet
