20 Most Recent Hitachi 50V720 Television Questions & Answers
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Hitachi 50V720... | Answered on Sep 14, 2017
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Hitachi 50V720... | Answered on Jan 31, 2015
This is a common problem with that series of TVs.
See: http://www.fixya.com/support/t10480975-hitachi_50v720_picture_fuzzy_color
Warranty is probably not an option anymore, and replacing the bulb could be a costy gamble, even when done yourself. It's probably the electronics. Since replacing those is more expensive than a new TV, I would suggest giving up on it. Sorry :(
Hitachi 50V720... | Answered on Jun 27, 2014
It will be difficult to get. Anyway, contact the authorized service center for Hitachi. Gopakumar Gopalan Google
Hitachi 50V720... | Answered on Feb 18, 2014
Faulty capacitors
Hitachi 50V720... | Answered on Dec 05, 2013
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
google.com/+GopakumarGopalan
Hitachi 50V720... | Answered on Nov 13, 2013
It likely has more than one, the main fan should be right at the lamp inside and another should be on the digital board, most of these have at least two fans, got some issue?
Hitachi 50V720... | Answered on Dec 10, 2012
Hello, I'm sorry to tell you that that set has a bad optical assembly. The blue part has gone bad and cause's either a yellowing of the screen or blue spotting or both. You can purchase a new lcd tv cheaper than you can repair that one. Do not replace the lamp, it's not what's wrong with it, and you'll just waist your money. thanks, Terry
Hitachi 50V720... | Answered on Oct 09, 2012
Check this link to get more details. Blinking codes to this TV is described in detail there.
Hitachi 50V720... | Answered on Sep 23, 2012
The simple test I would make is hook something to the rear audio and video inputs and see if when cold you have the problem there.
If your main signal in is via the cable fitting make sure cable is connected and if the set does not display the issue via rear audio/video jacks you can (most sat and cable boxes have this) route your signal via an unused set of audio and video jacks thus bypassing the tuner
Hitachi 50V720... | Answered on Apr 07, 2012
download this manual
http://merchant.satisfusion.com/sf/library/manuals/owners/50V720.pdf
see page 59,60,61,62. The problem can be the lamp
After extended use, if the TV picture turns dark, the color looks unusual or LAMP INDICATOR light turns on, then it
is time to replace the lamp with a new lamp.
Hitachi 50V720... | Answered on Feb 06, 2012
Hitachi 50V720 Television Logo
118 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi 50v720 yellowish color
  • Televison & Video
