20 Most Recent Hyun Won mobiBLU DAH-1700 (512 MB) MP3 Player Questions & Answers
Mobiblu DAH 1500i Battery
I formatted it with windows 7 and it read "no file" even with songs on it. Then I formatted it with windows XP and it worked!
1/5/2012 9:27:38 AM • Hyun Won mobiBLU... • Answered on Jan 05, 2012
0answers
0answers
I Need belts for a Realistic 909 Reel to Reel tape
I hear ya. I worked on many of these vintage machines back in the day. Sadly, nobody fixes things these days, they just buy new. I would give a call to Euclid Radio Parts in Mentor, Ohio. They "used to" carry things like belt-kits and individual belts. You might try the internet with search term "tape recorder belts" to see but that's a **** shoot. You may find you can "clean" the old belts using isopropyl alcohol and a paper towel. That's only a temporary fix and the issue will return. Good luck
10/20/2021 5:42:36 PM • Audio Players &... • Answered 3 days ago
Relay for amplifier sakura 735 is not working on or off.
test it if failed replace
10/19/2021 11:49:10 AM • Audio Players &... • Answered on Oct 19, 2021
What is meant by equity trading in sharemarket?
Equity trading is the buying and selling of company shares or stocks, also known as equities, on the financial market. There are a few ways in which you can invest in equities. Most equity trading refers to the buying and selling of public company shares through a stock exchange or as over-the-counter products. Every country has its own stock exchange (organized market), where shares of listed companies are bought and sold. These can vary across stock market sectors and industries, and each stock exchange has its own trading hours. These mainly apply to the weekdays and close on the weekends, although this does vary according to each country's timetable.
10/15/2021 5:22:00 AM • Audio Players &... • Answered on Oct 15, 2021
Hello, I have a set of
Hook them up conventionally 2 speakers to your right side of amp/receiver and the other 2 to left. (2 positive to rt side of receiver, 2 grounds to grounds rt side, left the same... you won't blow those speakers.
10/14/2021 4:37:39 PM • Audio Players &... • Answered on Oct 14, 2021
Need remote control and Manual for Pioneer VSX-D601
I Need remote control Pioneer VSX-D601
10/13/2021 9:12:20 AM • Audio Players &... • Answered on Oct 13, 2021
3answers
What's the best free music downloads site
You might check this website, it collects 20 legal and free music download websites. Top 20 legal and free music download websites Updated 2015
10/11/2021 3:03:52 AM • Audio Players &... • Answered on Oct 11, 2021
2answers
I need a good audio converter
I use this m4a to mp3 converter for the same purpose, it does all the work in a blink, try it, I am sure you will like it. And, by the way, it's free!
10/8/2021 5:41:25 AM • Audio Players &... • Answered on Oct 08, 2021
Ferguson dab radio frg-r116d. display back light not working. is there a way it can be changed
It's not easy - we had one in our Repair Cafe yesterday with the same problem. The backlight is a LED that is moulded into a perspex screen located behind the display. You will need a soldering iron, PH1 screwdriver, fine pliers, a file, Stanley knife, perspex glue and replacement cold white LED (preferably 3mm, but 5mm will do).To get at it, take out the front panel assembly (4 deeply recessed screws accessible from the back, and 2 at the front, accessible through the bottom). Then detach the front PCB assembly between the speakers (4 screws). The display is held onto this by 2 screws - remove the connector to the rest of it first. But before this, make sure power is getting to the PCB - power up the radio and check for about 5 volts between pins 11 and 12 of the connector. Also check that you can see something on the display by shining a bright light at it - if not, the display itself has broken - so no point in proceeding.The LED is at the right side of the display. Cut its leads and desolder remains from the PCB. Carefully lever up two metal tabs at the opposite end of the display (DO NOT ATTEMPT TO REMOVE THE WHOLE METAL COVER). You can then slide out the backlight unit to the left. The rectangular-bodied LED is superglued into the perspex - carefully prise it out with pliers.A 3mm LED should then fit the slot. Otherwise, file part of the dome of a 5mm LED to make it fit. Either way, push the LED into the slot, refit the backlight assembly and connect its leads to the PCB - positive to hole nearer to the connector. Then power it up to check it works. If all is good, apply a few drops of perspex glue round the LED body to retain it: this will also reduce light leakage. Carefully push back the two metal tabs.There are two surface-mount 15 ohm resistors (marked 150) on the PCB near the LED. These allow too much current through the LED, so to reduce risk of a further failure, remove both and replace with a single 150 ohm surface-mount resistor. If you have to use a leaded component, use the smallest you can and ensure it doesn't foul anything else when fitted. (This step is a nicety, but if not followed, the LED could fail again - lousy Chinese 'design'...)The back end of the LED will protrude further to the right than the original, which will foul the right speaker mount. Remove and discard the screw that will be affected and cut away sufficient plastic for the screen to fit properly.Then reassemble. Illumination might not be as even as before, but the display should be clearly visible. HTH.
10/3/2021 10:12:09 AM • Audio Players &... • Answered on Oct 03, 2021
3answers
I have a platinum karaoke no sounds only video.how
Hi Peter, has this issue been resolved? I am having the same problem at the moment.
10/3/2021 12:33:52 AM • Audio Players &... • Answered on Oct 03, 2021
My headphone knob is not working. It goes from low to busting your ear drum. Any advice would help..
Bad pot (the thing that has the shaft the knob is on), the only solution is to replace it.
10/2/2021 3:31:49 AM • Audio Players &... • Answered on Oct 02, 2021
3answers
Find song with a few lyrics
There are some ways to identify a song: Music software If you have a PC running Windows 7 or previous versions, you can use some music software to identify songs. Leawo Music Recorder can be used in this case. It can identify songs based on networked database, and then save recordings into MP3 and WAV. Just click the record button to get started. Online music identifier Except software above, you can also use online music identifier to identify songs online. Go to ACRCloud Music Recognition and then choose a file to upload. It will automatically identify songs and show result on the interface for you. Music recognizing app On iPhone, you can use Shazam, and on Android phone, you can use Google Assistant. As long as you sing to them, they will match with the best result.
9/29/2021 11:53:40 AM • Audio Players &... • Answered on Sep 29, 2021
6answers
How to convert video .dav in .avi
the best video converter i have found is called Xylisoft media converter it has just about every type of video conversion that you could want to do
9/28/2021 10:16:54 PM • Audio Players &... • Answered on Sep 28, 2021
I have a Steepletone SMC98R and I want to buy a new stylus for it. do you know where I can get one please?
9/28/2021 2:51:05 PM • Audio Players &... • Answered on Sep 28, 2021
Hyun Won mobiBLU DAH-1700 (512 MB) MP3 Player Logo
Popular Tags
5 questions posted
Top Hyun Won Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Hyun Won Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Hyun Won Audio Players & Recorders
Most Popular Question
mobiblu dah 1500i battery
  • Audio Players & Recorders
