20 Most Recent Ranger Virage VX-38 Base CB Radio Questions & Answers
its kind of late now but if it were my radio I would have a tech repair it and double check out any other problems the radio might have while he has it apart.
Ranger Virage... | Answered on Feb 23, 2015
two are for power ,the third is a ground. be sure to have a fuse in both wires.
disconnect your internal speaker and see if it helps. Its a poor power supply filtering problem and it effects the speakerin many ways.check to see if it hums with only the external speaker attached.
Ranger Virage... | Answered on Jul 23, 2014
Check RF transistor may have leakage, "probably won't show up on a regular meter, carefully inspect board for bad solder connections, buy semiconductor cold spray may help tracking faulty part.
Ranger Virage... | Answered on Mar 24, 2012
I can only guess you are asking about the echo board control on face for echo board.
Echo inner and time or speed outer ring control.
Ranger Virage... | Answered on Aug 27, 2011
Once its been hooked up backwards you have to change your diode in the radio,please do not keeping changing the fuse all you're going to do is mess the radio up worst,take it to a shop and let them repair it,and yes it is fixable if they tell you other wise get your radio and go to another shop.
Ranger Virage... | Answered on Jul 10, 2011
Thats because your Rf is powerful on high settings..try taping a AM radio "ferrite bar" to your coax in the back of radio for "RF filtering". Keep your power supply 15 inches away from radio. I recommend unhooking talkback on radios (it always causes feedback). But make sure speaker is good distance from the radio. I'd say 10 feet or so, behind radio. Change external speakers or add one with a long cord.
Ranger Virage... | Answered on Apr 25, 2011
Try www.cbtricks.com
They probably have one you can read on line for FREE.
Ranger Virage... | Answered on Feb 18, 2011
Then seem like need a new audio transistor. tr51?tr52?
Ranger Virage... | Answered on Dec 16, 2010
This website has all sorts of info on CB Radio's. This link will take you to the Ranger 2980. If you can't find what you are looking for there then you may be stuck.
Ranger Radio... | Answered on Nov 10, 2019
check out the schematic first .It may be the same wiring .
Ranger Radio... | Answered on Oct 03, 2018
Your radio needs an alignment to bring it back to specs . Check all the frequencies according to the manual and have a tech tune it for you .
If you want to talk on AM put it on AM if you want to talk on SSB then put it on SSB. Did you recently purchase this radio? You do realize you need a ham radio license to use this ?If you are on the upper ham bands you better have a license or they will come and get you .Look at the the dial that has 1 - 7 on it. Now take the owners manual and look at the diagram of the knob . It should say something about frequencies and the frequency you need to operate on is from 26.965 to 27.405 MHZ .
Ranger Radio... | Answered on May 06, 2016
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
Ranger Radio... | Answered on Jan 10, 2016
The + side of the cell is smooth on the top (no seam), and the - side has a seam going all the way around it as shown below:
This side ^ is (+) and this side ^ is (-)
Ranger Radio... | Answered on Oct 20, 2015
Ranger Virage VX-38 Base CB Radio Logo
10 questions posted
Top Ranger Radio Communications Experts
Robert McClure
normis101
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Ranger Radio Communications
Most Popular Question
power cord vx 3300
  • Radio Communications
