20 Most Recent Ranger SS-3900 240-Channels Base CB Radio Questions & Answers
Hi . Have Cobra 148..But the Driver tx
The 1969 is probably bad. Replace it.
6/29/2011 2:36:01 PM • Ranger SS-3900... • Answered on Jun 29, 2011
Turn down my talkback
find the auido horseshoe turn it down
9/16/2008 5:04:12 PM • Ranger SS-3900... • Answered on Sep 16, 2008
I have a 6 wire D104 . How do I wire it to a Ranger 2985 dx ?
Wiring a 6-wire D104 microphone to a Ranger 2985 DX requires connecting the wires in the correct order and configuration. The Ranger 2985 DX has an 8-pin modular plug, and the D104 microphone has a 6-pin modular plug. Here's one way to wire the D104 microphone to the Ranger 2985 DX:
  1. Connect the red wire from the D104 to the 8-pin modular plug's pin 4 (PTT - Push-To-Talk).
  2. Connect the black wire from the D104 to the 8-pin modular plug's pin 5 (Ground).
  3. Connect the white wire from the D104 to the 8-pin modular plug's pin 6 (MIC + Audio).
  4. Connect the blue wire from the D104 to the 8-pin modular plug's pin 7 (Receive Audio)
  5. Connect the green wire from the D104 to the 8-pin modular plug pin 8 (Transmit Audio)
  6. Connect the yellow wire from the D104 to the 8-pin modular plug's pin 3 (UP-Down).
It's important to double-check the wiring configuration with the user manual of the Ranger 2985 DX and the D104 microphone. Some manufacturers have different wiring configurations and it's important to match the wiring accordingly to avoid any damage to the device. It's also worth noting that if you are not comfortable with the wiring process, it's best to consult with a professional technician or a radio expert.
1/28/2023 12:45:23 AM • Ranger Radio... • Answered on Jan 28, 2023
2answers
Led display
Hi John,Ranger CB YES, Model No. NO, led display, YES IT HAS ONE OF THOSE.More info please john.The more info about the radio you give and the problem, the easier it is to give you assistance, we can't answer buy guess work, it's neither helpful nor pleasant.Cheers,Peter
12/4/2022 7:46:51 PM • Ranger Radio... • Answered on Dec 04, 2022
How do I convert a Ranger SS39 10 meter radio to 11 meters?
Doing this is *******.
11/10/2019 8:54:40 PM • Ranger Radio... • Answered on Nov 10, 2019
Got ranger 2980 6pin going to 4 pin,cobra.whats wiring order?
This website has all sorts of info on CB Radio's. This link will take you to the Ranger 2980. If you can't find what you are looking for there then you may be stuck.
11/10/2019 2:35:47 PM • Ranger Radio... • Answered on Nov 10, 2019
I am trying to wire a Ranger SRA-198 4-Pin mike to a Ranger 3500 4 pin Radio
check out the schematic first .It may be the same wiring .
10/3/2018 8:08:02 PM • Ranger Radio... • Answered on Oct 03, 2018
I HAVE A RANGER rci2980wx I have no transmit audio on am side only it works good on usb,lsb and fm it transmit on there my recive is good on all channels
Your radio needs an alignment to bring it back to specs . Check all the frequencies according to the manual and have a tech tune it for you .
10/3/2018 8:06:40 PM • Ranger Radio... • Answered on Oct 03, 2018
Just got a ranger rci69ffb4 CB radio. I do not know how to operate it. What band number to put it on to talk. There is 1-7 on it. And do I put it on an or ssb mode. Thanks
If you want to talk on AM put it on AM if you want to talk on SSB then put it on SSB. Did you recently purchase this radio? You do realize you need a ham radio license to use this ?If you are on the upper ham bands you better have a license or they will come and get you .Look at the the dial that has 1 - 7 on it. Now take the owners manual and look at the diagram of the knob . It should say something about frequencies and the frequency you need to operate on is from 26.965 to 27.405 MHZ .
5/6/2016 4:57:22 PM • Ranger Radio... • Answered on May 06, 2016
Where does the e-chip plug in on the ranger rci 2995
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
1/10/2016 12:08:25 AM • Ranger Radio... • Answered on Jan 10, 2016
On the internal battery on a ranger 2950 is the top of the battery positive and bottom negitive? The battery is completely dead?
The + side of the cell is smooth on the top (no seam), and the - side has a seam going all the way around it as shown below: 25916148-r0yzlqghevn4wmvg3zw5spzn-3-0.jpg This side ^ is (+) and this side ^ is (-)
10/20/2015 1:41:05 AM • Ranger Radio... • Answered on Oct 20, 2015
What is the RCI-6060 Ranger Communications radio used for?
ship to shore communication and weather reports.
10/1/2015 6:45:12 PM • Ranger Radio... • Answered on Oct 01, 2015
Is the RCI-6060 by Ranger Communications a marine radio?
Do like I just did,Google it and your answer will be an affirmitive YES.
10/1/2015 6:44:11 PM • Ranger Radio... • Answered on Oct 01, 2015
I need a signal meter for my ranger new or used any one out there got one its the same as the superstar 3900.
this is fixya,not the want ads,please remove this post
7/27/2015 4:46:59 AM • Ranger Radio... • Answered on Jul 27, 2015
My galaxy dx 55 hp is getting hot at right rear on am modulation causing modulation distortion
take it to a tech , if you have to ask then you are not able to work on it . It is definatly an internal problem.
7/17/2015 7:19:58 PM • Ranger Radio... • Answered on Jul 17, 2015
Ranger SS-3900 240-Channels Base CB Radio Logo
4 questions posted
Top Ranger Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Ranger Radio Communications
Most Popular Question
cobra 148 but driver tx
  • Radio Communications
