20 Most Recent Ranger VR-9000 Base CB Radio Questions & Answers
Astaic 36L. You never want to run a power Mike with a good radio with Mic Gain. Road King is great to. It is very hard to find the honey spot with a power Mike when you have Mike gain on radio.I think it is pretty hard to beat the 36L. I use one one my Connex 4600 Turbo and Galaxy 95T2, They both performe great. Connex is a little better a DX ing though
Ranger VR-9000... | Answered on Jun 08, 2015
First , is this radio new or used ? If it is new I see no dial for talk back and if it is used then was talk back added to it ? Open the radio so you can check out trace side of the radio and look to where the speaker jacks plug in. If you see a resister soldered across them then disconnect it and your talk back is gone,unless you still want it then solder a 220 ohm resister in place of the one you removed. if the radio is out of the box new then it should be adjustable but as I look at the face I see no knob marked as talk back.If you ordered this radio and asked for talk back on a seperate switch then which one ? look at it and make the call as to which wires to cut and do it .
Ranger VR-9000... | Answered on Feb 23, 2015
RCI is part of the Galaxy company based in San Diego, California---
A call there may resolve how if possible to do this--if built into the radio it may be possible to defeat it---if someone added it then it will be a part very close to the speaker jack on rear of the unit.
Ranger VR-9000... | Answered on Jun 07, 2012
Here is a diagram of the wiring.
Regards, Tony
Ranger VR-9000... | Answered on May 04, 2011
radio needs to be aligned.
Ranger VR-9000... | Answered on Apr 07, 2010
SOUNDS LIKE A COLD SOLDER JOINT OR A BAD COMPONNET WHEN IT WARMS UP THATS WHEN IT STARTS ..TAKE OFF THE COVER SO THAT YOU CAN SEE THE SOLDER SIDE OF THE BOARD PUT POWER TO THE RADIO AND WHEN IT WARMS UP AND SHUTS DOWN TAKE A LITTLE PIECE OF WOOD OR PLASTIC AND PROBE ALL THE SOLDER CONNECTIONS TO CHECK FOR A COLD SOLDER JOINT IT MAY BE GRAY IN COLOR MAY NOT.. SEE IF IT GOES ON AND OFF.. IF SO RESOLDER THAT SOLDER JOINT.......IF THIS DOES NOT WORK ....PICK UP SOME FREEZE SPRAY AND SPRAY IT ON THE COMPONNETS ON THE OUTHER SIDE OF THE BOARD THIS IS WHAT A SERVICE PLACE WILL DO IF THAT DOES NOT WORK NOW BRING IT TO A SERVICE AND LET THEM SCRATCH THERE HEAD GOOD LUCK
Ranger VR-9000... | Answered on Feb 21, 2009
This website has all sorts of info on CB Radio's. This link will take you to the Ranger 2980. If you can't find what you are looking for there then you may be stuck.
Ranger Radio... | Answered on Nov 10, 2019
check out the schematic first .It may be the same wiring .
Ranger Radio... | Answered on Oct 03, 2018
Your radio needs an alignment to bring it back to specs . Check all the frequencies according to the manual and have a tech tune it for you .
If you want to talk on AM put it on AM if you want to talk on SSB then put it on SSB. Did you recently purchase this radio? You do realize you need a ham radio license to use this ?If you are on the upper ham bands you better have a license or they will come and get you .Look at the the dial that has 1 - 7 on it. Now take the owners manual and look at the diagram of the knob . It should say something about frequencies and the frequency you need to operate on is from 26.965 to 27.405 MHZ .
Ranger Radio... | Answered on May 06, 2016
on the back of the cpu behind the frequency counter display. you will see the pins sticking out
Ranger Radio... | Answered on Jan 10, 2016
The + side of the cell is smooth on the top (no seam), and the - side has a seam going all the way around it as shown below:
This side ^ is (+) and this side ^ is (-)
Ranger Radio... | Answered on Oct 20, 2015
ship to shore communication and weather reports.
Ranger Radio... | Answered on Oct 01, 2015
Do like I just did,Google it and your answer will be an affirmitive YES.
Ranger VR-9000 Base CB Radio Logo
Popular Tags
6 questions posted
Top Ranger Radio Communications Experts
normis101
John L radiodude365
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Ranger Radio Communications
Most Popular Question
best power mic ranger vr 9000
  • Radio Communications
