20 Most Recent JVC GR-DVL120 Mini DV Camcorder Questions & Answers
0answers
My camera was working fine
This is usually caused by a defective CCD image sensor. This will require disassembling the camera and removing the lens assembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
8/27/2011 5:50:13 PM • JVC GR-DVL120... • Answered on Aug 27, 2011
I have No sound on playback
check menu for options,,make sure its turn on or up ,,
11/3/2010 3:09:13 AM • JVC GR-DVL120... • Answered on Nov 03, 2010
Camcorder does not play video
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
9/3/2010 7:24:46 PM • JVC GR-DVL120... • Answered on Sep 03, 2010
The screen gives me E04
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
9/3/2010 6:24:17 PM • JVC GR-DVL120... • Answered on Sep 03, 2010
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
11/14/2008 9:23:21 PM • JVC GR-DVL120... • Answered on Nov 14, 2008
GR-DVL120
best buy... firewire i believe its a "4 to 6" or a "4 to 8" its basically a usb to the camera which plugs into the "DV" slot on the inside of the screen.
10/28/2008 9:32:05 PM • JVC GR-DVL120... • Answered on Oct 28, 2008
My JVC Camcorder's screen is black and won't record.
http://www.jvcservice.com/service/custnoticecamcorder.asp?ReqType=CCD
See if your camcorder is listed on the JVC site for free repair...apparently this was a common problem.
4/22/2008 7:50:50 PM • JVC GR-DVL120... • Answered on Apr 22, 2008
Image won't flip when the lcd panel is fliped to 180
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
8/20/2006 9:24:19 PM • JVC GR-DVL120... • Answered on Aug 20, 2006
I have a jvc camcorder model gr-d350u that will not come out of safeguard mode
Not sure , do you mean safe mode ?
1/24/2019 4:34:16 PM • JVC GR Video... • Answered on Jan 24, 2019
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery. Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
11/13/2017 11:45:25 AM • JVC GR Video... • Answered on Nov 13, 2017
Not used my vid cam for a long time but when played back some tapes played great. The following day I tried playback on the tapes & they all showed a blue screen. No images What am I doing wrong?
not sure on this one but it might be the heads in your vid cam may need cleaning. or the tapes are not running straight on the heads or the rollers in side. if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp. try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture. this could also be a head misalignment fault if it is you will have to take it to some one to have a look at. if any of the above does not work then you will have to take to some one to look at it. .
11/27/2016 9:48:19 PM • JVC GR Video... • Answered on Nov 27, 2016
Cmy JVC camcorder will not start is model GZHdaA
Sounds as if the battery needs replacing - have you tried with a spare battery ?
10/8/2016 12:49:40 AM • JVC GR Video... • Answered on Oct 08, 2016
0answers
I have bad audio static when playing my mini dv tapes on two JVC MIni DC Video cameras model GR-D244U and GR-D370U,need help?
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
9/12/2016 6:26:58 PM • JVC GR Video... • Answered on Sep 12, 2016
I misplaced mysoftware disc fr the camera and just bought a new computer. how can I retrieve pictures from my camera onto my desktop?
Do you have the sd card that holds the pictures? Put in computer. Computer will give you option how to open and save photos. You do not have to use makers software disc, any photo reader can store your pictures on computer.
11/28/2015 3:09:03 AM • JVC GR Video... • Answered on Nov 28, 2015
Video Cameras Logo
Popular Tags
13 questions posted
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Steven Wander
Steven Wander
Marco Avila
Marco Avila
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
jvc gr dvl120 playback
  • Video Cameras
