20 Most Recent JVC SR-MV40 DVD Recorder/VCR Questions & Answers
It keeps blinking "loading" and
theres trash inside vcr you will need tape cleaner to clean out vcr.
3/30/2011 7:24:55 PM • JVC SR-MV40 DVD... • Answered on Mar 30, 2011
2answers
I need to know what formats you can record a DVD and which is bes
Hey!
I am now using Wondershare DVD Ripper Platinum which can turn DVDs into almost any video format directly including FLV video you have mentioned. So you can have a try of it and convert your DVD into FLV video directly. You can free download it at it's official web: http://www.dvd-ripper-copy.com/dvd-ripper-platinum.html#181. For how to use it, you can refer the official guide at: http://www.dvd-ripper-copy.com/guide/dvd-ripper-tutorial.html#181.
Hope that helps.
9/25/2009 3:21:20 AM • JVC SR-MV40 DVD... • Answered on Sep 25, 2009
I have a JVC SR-MV40
press stop button twice then go into menu ckick on finalize disk!
12/16/2008 1:59:16 AM • JVC SR-MV40 DVD... • Answered on Dec 16, 2008
Finalization of Disks
Failing to Finalize and thus making the DVD 'playable' on other DVD Players is most often caused by the media (your blank disk), not the Recorder. Trying another disk, from the same 'stack' or manufacturer will often have the same result. But, it is a 'hit and miss' situation. As you have the recording on the hard drive it can be worth your while connecting another basic DVD Recorder to input the material to a disk in that recorder. Sounds silly perhaps, but I have actually done this - and had the disk finalized in the second unit.
1/28/2008 4:11:43 PM • JVC SR-MV40 DVD... • Answered on Jan 28, 2008
JVC 43" (109cm) HD Ready Plasma TV PD43N30A. Chunghop universal remote codes for JVC pd43n30a
Question edited for a lot more clarity, plus Chunghop not chungCHOP :>D JVC: 089, 161, 909
CHUNGHOP Universal Remote Control Codes
codesforuniversalremotes.com https://codesforuniversalremotes.com > chunghop-univer... Jul 25, 2019 - CHUNGHOP Universal Remote Control Codes ; Aiwa: 009, 057, 058 ; Samsung: 618, 619, 620, 621 ; Philips: 013, 023, 024 ; Hisense: 676, 677, 707, 898
3/20/2024 5:38:12 PM • JVC Televison &... • Answered on Mar 20, 2024
2answers
My jvc smart tv is not passing the android logo how do i fix
try unplugging the unit. Press and hold power button for 10-20 sec's then try again
3/17/2024 3:32:51 AM • JVC Televison &... • Answered on Mar 17, 2024
JVC I Art Pro AV-56WP74. It has a cracked outer screen and I can't find anywhere to replace it. I want to fix the problem.
Question edited for clarity. If is is the outer clear screen, replace it with a a sheet of Lexan Polycarbonate sheet cut to size. Lexan is bulletproof. https://www.google.com/search?q=clear+polycarbonate+sheet+cut+to+size Sears list it but no longer available. After all Rear Projection Televisions are antique dinosaurs. Technology has moved on :>D https://www.searspartsdirect.com/model/33xrqyx4kj-001758/jvc-av-56wp74-television-parts https://www.google.com/search?q=jvc+i+art+pro+av56wp74+parts Service Manual https://www.manualslib.com/manual/2744485/Jvc-Av-56wp74.html#manual ..
11/10/2023 11:43:38 PM • JVC Televison &... • Answered on Nov 10, 2023
I have Jvc receiver RX-5060 is not switching on, it is always on standby
  1. Reset the receiver: To reset your JVC RX-5060 receiver to its factory default settings, switch off the receiver and unplug it from the power outlet. Press and hold the "Power" button on the front panel for approximately 5 seconds.Then, while still holding the "Power" button, plug the receiver back into the power outlet2.
  2. Check the fuse: If your receiver still doesn't turn on, check if there's a blown fuse in the receiver.If so, replace it with a new one of the same rating3.
If none of these steps work, it's best to contact a professional or JVC's service center for further assistance. I hope this helps!
8/27/2023 7:04:23 PM • JVC Televison &... • Answered on Aug 27, 2023
My JVC TV has an onscreen remote that doesn't let us use the actual remote what do I do to gat it out?
Hello! If your JVC TV is displaying an onscreen remote and you're unable to use the actual remote, you can try the following steps to resolve the issue:
  1. Power cycle the TV: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can often reset any temporary issues and restore the functionality of the actual remote.
  2. Replace the remote batteries: Check the batteries in your remote control and make sure they have enough power. If the batteries are low, replace them with fresh ones and try using the remote again.
  3. Check the remote control sensor: Ensure that there are no obstructions between the remote control and the TV's remote control sensor. Clean the remote control sensor on the TV with a soft, lint-free cloth to remove any dust or debris that may be interfering with the signal reception.
  4. Reset the TV to factory settings: If the issue persists, you can try resetting the TV to its factory settings. Keep in mind that this will erase any personalized settings and restore the TV to its original configuration. Refer to the user manual or the manufacturer's website for instructions on how to perform a factory reset on your specific JVC TV model.
  5. Contact JVC customer support: If none of the above steps resolve the issue, it's recommended to reach out to JVC customer support for further assistance. They will have access to more specific troubleshooting steps and can guide you through the process of resolving the issue with the onscreen remote.
Keep in mind that the exact steps and options may vary depending on your specific JVC TV model. Refer to the user manual or contact JVC customer support for model-specific guidance.
7/2/2023 4:31:45 PM • JVC Televison &... • Answered on Jul 02, 2023
Jvc crt tv model no. Av28x25ekgy has a problem of video lines through the screen green in colour
Either the A1 controls are misaligned or the tube is weak.
7/2/2023 12:06:21 PM • JVC Televison &... • Answered on Jul 02, 2023
JVC SR-DVM700U the front display is dimming quit low to where i cant read it
If the front display of your JVC SR-DVM700U is dimming to the point where it is difficult to read, there are a few potential causes and troubleshooting steps you can try: 1. Adjust the display brightness: Check if your device has a dedicated display brightness control. It could be a physical knob or a setting in the menu system. Increase the brightness setting to make the display more visible. Refer to the user manual for specific instructions on how to adjust the display brightness. 2. Check the power source: Ensure that the device is connected to a stable power source. If the power supply is fluctuating or inadequate, it can cause the display to dim. Try plugging the device into a different power outlet or using a different power cable to rule out any power-related issues. 3. Clean the display: Dust, dirt, or fingerprints on the display surface can also affect visibility. Gently clean the front display using a soft, lint-free cloth. Avoid using harsh chemicals or abrasive materials that could damage the display. 4. Check for backlight issues: The display might have a backlight that illuminates it. If the backlight is malfunctioning or failing, it can result in dimness. Unfortunately, in most cases, repairing or replacing the backlight requires professional assistance. Consider contacting a qualified technician or JVC customer support for further guidance and potential repairs. 5. Reset the device: Perform a factory reset on your JVC SR-DVM700U. This can help resolve any software-related issues that may be affecting the display. Consult the user manual or contact JVC customer support for instructions on how to perform a factory reset on your specific model. If the above steps don't resolve the issue, it is recommended to reach out to JVC customer support or consult a professional technician who specializes in JVC audio/video equipment. They can provide further troubleshooting guidance or recommend appropriate repairs if necessary.
6/19/2023 7:47:27 PM • JVC Televison &... • Answered on Jun 19, 2023
How do I know if I need 3 digit code or 4 Digit code for my jvc Lt24 c600 smart tv?
Your user manual will tell you.
6/9/2023 8:16:01 AM • JVC Televison &... • Answered on Jun 09, 2023
JVC 32"(81cm) Full HD LED TV (LT-32N310A). Does anyone know the Remote Model Number?
Question edited for clarity.Or buy using the television model, not by remote model. Walmart carry them. Check model number carefully when looking at Amazon and eBay listings.https://www.google.com/search?q=JVC+LT-32N310A+replacement+remoteTwo specialist websites in this Fixya Tip I wrote about Remotes.https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote....
5/12/2023 4:07:20 PM • JVC Televison &... • Answered on May 12, 2023
JVC AV-36260 Television. VIDEO 1 INPUT displays only in 'Picture-in-Picture'.
Generally service manuals aren't available for newer TV's or I should say anything that's under 10 years old
5/2/2023 8:40:16 AM • JVC Televison &... • Answered on May 02, 2023
I have a jvc 40in model LT 40A 32C.THERE IS NO SOUND FROM SPEAKER OR EXTERNAL SPEAKER PORTS.
Here are some troubleshooting steps you can try to fix the sound issue on your JVC TV:
  1. Check the volume level: Make sure that the TV volume is not muted and the volume level is high enough to be audible.
  2. Check the connections: Ensure that the audio cables are properly connected to the TV and the external speakers. If you're using an external audio device, check its connections as well.
  3. Try resetting the TV: Turn off the TV and unplug it from the power source for a few minutes. Then plug it back in and turn it on.
  4. Check the audio settings: Access the TV's audio settings menu and ensure that the sound mode is set to "Stereo" or "Mono". You can also try changing the audio output settings to "TV Speakers" or "External Speakers" depending on what you're using.
  5. Try using a different audio device: If the above steps don't work, try connecting a different audio device to the TV to see if the sound works. This will help you determine if the problem is with the TV or the audio device.
If none of these steps work, it's possible that there may be an issue with the TV's audio hardware, and you may need to contact a professional repair service or the manufacturer for further assistance.
2/28/2023 5:35:08 AM • JVC Televison &... • Answered on Feb 28, 2023
When I try to turn on my jvc projection tv the red light by the power button blinks 2 times and tv won't turn on?
The blinking red light on your JVC projection TV could indicate a problem with the TV's power supply, lamp, or other internal component. Here are some steps you can take to try to resolve the issue:
  1. Check the power cord: Make sure the power cord is plugged in securely to the TV and the power outlet. If the cord is loose or damaged, the TV may not receive the power it needs to turn on.
  2. Reset the TV: Unplug the TV from the power outlet and wait a few minutes before plugging it back in. This may reset the TV's internal system and resolve the issue.
  3. Replace the lamp: If the TV has been used for a long time, the lamp may be burnt out and need to be replaced. Check the owner's manual or contact JVC customer support for instructions on how to replace the lamp.
  4. Contact customer support: If none of the above steps work, the TV may have a more serious problem that requires professional repair. Contact JVC customer support for assistance or to find an authorized repair center in your area.
2/26/2023 2:38:02 PM • JVC Televison &... • Answered on Feb 26, 2023
Older JVC VHS model VP 782 U/UC will not load a VHS cassette
If your JVC VHS model VP 782 U/UC is not loading VHS cassettes, there could be a few possible causes. Here are a few things you can try: Check the tape: Make sure the VHS cassette is not damaged, dirty, or warped. Clean the tape heads and tape path with a VHS head cleaner if necessary. Check the loading mechanism: Make sure the loading mechanism is free of debris or obstructions. Open the VHS deck and visually inspect the loading mechanism for any visible issues. Check the drive belt: Over time, the rubber drive belt that pulls the tape through the VHS deck can become worn or loose. Open the deck and check the drive belt for any signs of wear or slack. If the belt is loose or damaged, it may need to be replaced. Check the loading motor: If the drive belt is fine, the issue could be with the loading motor. The motor may have burned out or become faulty, preventing the tape from being loaded properly. In this case, the motor may need to be replaced. If none of these steps resolve the issue, it may be necessary to take the VHS player to a professional repair shop for further diagnosis and repair.
2/24/2023 2:31:19 PM • JVC Televison &... • Answered on Feb 24, 2023
Can you connect a dvd player to a jvc 703x receiver?
Yes, you can connect a DVD player to a JVC 703X receiver. You can use an HDMI cable or RCA cables to connect the DVD player to the receiver. Make sure to select the appropriate input source on the receiver to play the DVD player's audio and video.
2/20/2023 7:28:34 PM • JVC Televison &... • Answered on Feb 20, 2023
JVC SR-MV40 DVD Recorder/VCR Logo
Popular Tags
9 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
keeps blinking loading
  • Televison & Video
