20 Most Recent JVC HR-XVC18B DVD Player/VCR Questions & Answers
VCR/Tuner Video Problem - DVD Playback Issue
What is the unit, exactly? Make, model, etc.? Your description sounds like an AFT (automatic fine tuning) problem ... but is it hooked up right?
5/10/2017 1:35:47 AM • JVC HR-XVC18B... • Answered on May 10, 2017
Need a code for a V2Go dvd player to go on a
I am looking for the DVD code for a v2go player. DP838. I'm trying to program a rca remote. Help please
3/29/2017 10:46:13 PM • JVC HR-XVC18B... • Answered on Mar 29, 2017
Reads cds but does not read dvds
There is hope to recover from semiconductor problems such as condesation or overheating. You have to play cd as long as possible, let the unit cool down. Then try dvd again. If works, keep standby power on, forever, to keep moisture out of your dvd/vcr combo.
10/15/2010 2:14:30 PM • JVC HR-XVC18B... • Answered on Oct 15, 2010
A kid put in a dvd upside down [shiney side
try unplugging it for a few minutes then try it again or pick up a dvd lens cleaner disc
9/13/2009 3:22:33 AM • JVC HR-XVC18B... • Answered on Sep 13, 2009
Image split with black bar in middle
check leads if they are connect in the normal video slot on dvd player and chek the player settings what out pot it is on
8/22/2009 1:27:03 AM • JVC HR-XVC18B... • Answered on Aug 22, 2009
I have a vertical black line down the middle of the screen while watchin a dvd. This happened one day after installing surround sound.
ur surround sound is to much power for the dvd player it is pushing te power throw the dvd player
5/27/2009 4:54:57 PM • JVC HR-XVC18B... • Answered on May 27, 2009
How do I turn on my JVC LT-40N555 TV when screen is black and red light is not on
Hi there! Typically the red light on lots of appliances (TV'S in particular) indicate power is available to the appliance, is this so on your tv? If so the first thing you should focus on is resetting the breaker associated with that power outlet or changing outlets. If there is a reset button on the tv then push it. After you do this we can go on to the next steps- it sounds like the set is not getting any power so let make sure then get back to me. Good Luck and Thanks Mr.Mike
12/6/2022 1:39:17 PM • JVC Televison &... • Answered 13 minutes ago
How do I identify the reason why my JVC LT32C672 TV has lost the video output. (Red LED flashes on power up)
Unless you have electronic schooling and the equipment don't attempt to fix it yourself, it's a guessing game as far as what board, backlights or panel is causing the issue unless you have equipment, knowledge and service manual recycle it.
11/28/2022 3:47:01 AM • JVC Televison &... • Answered on Nov 28, 2022
What is the code of JVC LT-32n33oA 32 inch please?
Question edited for clarity. That wasn't a 'serial number', it is the model number. What sort of 'code', universal remote code? Read this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/10/2022 10:29:48 PM • JVC Televison &... • Answered on Nov 10, 2022
5answers
How do i download Spotify to my jvc smart tv
I know the way for TCL Smart TV.you can install Spotify channel on TCL Smart TV via Roku Streaming Player or use the Spotify Music Converter from Tunelf to remove DRM protection from Spotify music and make them playable on any other device or platform.
11/10/2022 11:38:31 AM • JVC Televison &... • Answered on Nov 10, 2022
I have a 1080p jvc projection tv and I broke the bulb door safety switch. Can I bypass it so my tv will power on?
Hi Kyle, It isn't really recommended to bypass any of the safety switches in the TV. Maybe there is some other switch you can buy and install on the TV. What is the model number on the TV?
11/9/2022 12:42:05 AM • JVC Televison &... • Answered on Nov 09, 2022
JVC model DR-MV78BU DVD/VCR Combo Recorder does not recognize blank discs or a regular movie disc?
Hi, Please make sure that the discs do not have scratches . Then, you can clean any lens that the jvc machine uses to read your disc. Afterwards, you can attempt to play the discs again. If this does not work, please factory reset your device before attempting again. Otherwise, I think you might need to have the device repaired or potentially replaced. Thank you.
10/26/2022 5:25:06 PM • JVC Televison &... • Answered on Oct 26, 2022
JVC HR-XVC18B DVD Player/VCR Logo
12 questions posted
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
vcr tuner video problem dvd playback
  • Televison & Video
