20 Most Recent JVC GD-V502U 50 in. Plasma Television Questions & Answers
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
JVC GD-V502U 50... | Answered on Dec 20, 2017
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
JVC GD-V502U 50... | Answered on Aug 09, 2014
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
try using a can of compressed air to blow all the air vents out. could be overheating.
JVC GD-V502U 50... | Answered on May 03, 2011
Use the App Search feature.
JVC Televison &... | Answered 22 hours ago
Without a remote control, you can't.
JVC Televison &... | Answered on Jan 13, 2020
Google
make model reset
Press the "MENU" button on the remote to display the main menu. Highlight the "Setup" option using the up or down arrow buttons. Press the right arrow or "ENTER" button to access the Setup menu. Scroll down to "RESET" and press right arrow or "ENTER."
What are some ways to reset a JVC TV? - Quora
https://www.quora.com > What-are-some-ways-to-reset-a-JVC-TV
JVC Televison &... | Answered on Dec 25, 2019
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
You might want to go to Ebay and shop for a remote. How old is the tv?
JVC Televison &... | Answered on Dec 24, 2019
no one buys one for all remotes these days. You buy a facsimile remote just like the original. The codes are in the link
Search Results Web results
Remote Control Codes For Stereo Audio Receivers ' Codes ...
https://codesforuniversalremotes.com > remote-control-codes-for-stereo-au...
Feb 4, 2016 - JVC 0531, 1374, 1495, 1871, 2040, 2161, 2239, 2331. Kenwood ... Do you need a remote code for your Stereo Receiver that is not listed here?
JVC Televison &... | Answered on Dec 09, 2019
Sounds like the power supply has an issue. Sometimes unplugging it and holding the power button for 30 secs. or so MIGHT resolve it. If not, possible blown caps on power board.
JVC Televison &... | Answered on Dec 07, 2019
Steve White Dec 02, 2019
I SEE YOU GOT SEVERAL IRRELEVANT ANSWERS AND 1 GOOD ONE. YOUR BUTTON IS EITHER STUCK DOWN. (CAREFULLY TRY TO PRY IT UP WITH A KNIFE. OR SOMETHING WAS SPILLED INSIDE THE REMOTE. (OPEN IT AND CLEAN IT) SOMETIMES YOU CAN GET A NEW OEM REMOTE FROM EBAY FOR AROUND 5-8 DOLLARS.
JVC Televison &... | Answered on Dec 02, 2019
JVC GD-V502U 50 in. Plasma Television Logo
5 questions posted
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
tv suddenly shut off blinking red light
  • Televison & Video
