20 Most Recent Onkyo TX-SR602 Receiver Questions & Answers
2answers
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
3/17/2020 3:28:05 AM • Onkyo TX-SR602... • Answered on Mar 17, 2020
I HAVE A TX-SR602 ONKYO AV RECIEVER AND HAVING PROBLEMS WHEN SWITCHING TO DIFFERENT AUDIO SETTINGS (EXCEPT FOR DIRECT) THE SOUNDS ARE STATIC SOUNDING, LOUD AND JUST DOES NOT SOUND GOOD. I WOULD LIKE T
Your problem is in your DSP circuit. This what makes your different soround sound options.Coil L921 which is located on the DSP board may have opened due to in rush current.Check coil L921, if open, replace it with a new and improved coil.The Onkyo part# is 231237M022R2.
11/14/2018 4:44:04 PM • Onkyo TX-SR602... • Answered on Nov 14, 2018
manual
How do I fix my
Hello Allister, I would first start with a reset of the receiver. After the reset go into the level calibration menu. If you are still getting no audio test tones then the receiver would either have to be repaired or replaced. Thanks, FM9
7/8/2016 7:15:07 PM • Onkyo TX-SR602... • Answered on Jul 08, 2016
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
11/17/2014 1:47:01 AM • Onkyo TX-SR602... • Answered on Nov 17, 2014
What kind of screwdriver do I need to take apart my onkyo remote control rc-602m
Remote controls are NOT usually repairable I'm afraid!
1/9/2014 7:07:14 PM • Onkyo TX-SR602... • Answered on Jan 09, 2014
What kind of screwdriver do I use to take apart my onkyo rc-602m apart
Just look at the screws involved - usually they will be 'star' ones and sometimes very small as well as medium. Therefore get a good set of 'star' screwdrivers for your repair toolkit!
1/9/2014 7:03:07 PM • Onkyo TX-SR602... • Answered on Jan 09, 2014
There is no sound coming no matter what source
Have you checked the speaker select switch on the front of the receiver? "A" "B" or "A +B" or "Off". Sounds simple, but it happens! If you still have an issue post a comment and I can help you troubleshoot some more.
1/26/2013 2:33:23 AM • Onkyo TX-SR602... • Answered on Jan 26, 2013
Onkyo tx-sr602 no sound output
Check for your + and - 15Volts DC and + and - 7Volts DC. If they are not there, check the Regulators on that line and the resistors on that line.
5/10/2012 7:10:26 PM • Onkyo TX-SR602... • Answered on May 10, 2012
Powered zone 2 is not activated onkyo txsr602
You have to make sure that you have activated zone2 in setup? It is defaulted as 7.1 Activating zone2 makes it 5.1 + 2 (make sense)
Also zone2 only outputs audio hooked up thru the analog connections
8/20/2011 8:57:54 PM • Onkyo TX-SR602... • Answered on Aug 20, 2011
I have the receiver hooked
I don't know what kind of tv you have but, receivers can pass video along to the tv but, are not the best way to go. If you have the capability of running your video components dirctly to tv then sound out to receiver, you would get better results. Component video is great, as good as or, better than HDMI, the only advantage to HDMI is the audio but, digital optical for audio is great also. Component video cables can be tricky because you have to make sure the connectors are in all the way. If they are not inserted properly, you probably notice too much blue or green. While watching your cable, try twisting and pushing connectors and see if you notice any change in the color quality
5/22/2011 1:24:36 PM • Onkyo TX-SR602... • Answered on May 22, 2011
0answers
Where do I connect my unamplfied woofer I cant
You don't. It only supports a powered subwoofer. Item 24 on page 11 and page 22.
http://www.retrevo.com/support/Onkyo-TX-SR602-Receivers-manual/id/365ag211/t/2/
1/27/2011 11:15:07 PM • Onkyo TX-SR602... • Answered on Jan 27, 2011
I have an onyko HT-R538, for some reason I can't
you need to select speaker A or B option from the receiver. Also there are several Listening modes on your remote. Check these as well.
1/10/2011 10:39:42 AM • Onkyo TX-SR602... • Answered on Jan 10, 2011
Onkyo TX-SR602 Receiver Logo
40 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
tx sr602 onkyo av reciever having
  • Audio Players & Recorders
