20 Most Recent Euro-Pro Steam Generator EP8000 Iron Questions & Answers
0answers
2answers
NO STEAM COMES OUT: IT HASN'T
http://www.ehow.com/how_4899837_clean-shark-euro-pro-iron.html
This is the procedure for cleaning ..I guess if it do not produce any steam it has something blocking the steam ..(calcium deposits or such )
8/12/2011 7:21:00 PM • Euro-Pro Steam... • Answered on Aug 12, 2011
3answers
Steam builds up nicely in the tank, but the sole
There is most likely a disconnection from inside the ironthat's why it won't light up. If the iron has a three pin socket or plug,then open the plug and check if the fuse is intact. You canfind the suitable replacement parts online, like ebay.com orereplacementparts.com. Search with your model number and manufacturername.
6/24/2011 8:04:39 PM • Euro-Pro Steam... • Answered on Jun 24, 2011
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode. I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water. Be sure the vinegar will not damage the unit, I do not know. Hope these links help. http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf Euro Pro EP965 Use And Care Instructions Manual Euro Pro EP965 Carpet Cleaner User Manual Questions Answers for euro pro steam cleaner iron
5/29/2016 9:56:17 PM • Euro-Pro Irons • Answered on May 29, 2016
Handle on my steam iron is too hot to touch
Could be a hidden recall. I'd check MFG website, or email their customer service.
4/27/2015 3:22:54 PM • Euro-Pro Irons • Answered on Apr 27, 2015
How do you open the back plate to access the power connection. On a shark model G1568 iron??
We have a Euro Pro GI472, which kept going off and on, and the problem seemed to be an intermittent connection in the power circuit. If we "fiddled" with the cord, the power light would go off and on. To get the back off, I removed the two screws below the rubber feet, near the identification tag. Then I had to pop the red plastic light lens off the top of the iron. The lens is held by two plastic "claws" one at the top and at the bottom of the lens. Once the lens is out, there is a small Phillips-head screw visible between two light sources. I removed the screw, and that freed the cover, and made it possible to access the wiring. Testing continuity from the wall plug to the two wires inside the iron, and flexing the cord, quickly led to a spot in the cord that was slightly kinked, and that was the location of the fault. Both wires under the insulation were broken. In fact there were small balls of melted copper near the breaks. Then it is a matter of making sure you know which wire of the power cord goes to which spot in the iron (a photo or a sketch will save mistakes when reassembling) cutting out the faulty wire, getting a suitable crimp connector and a wire nut and rewiring the iron.
2/2/2015 12:40:46 AM • Euro-Pro Irons • Answered on Feb 02, 2015
Irons Logo
Popular Tags
13 questions posted
Top Euro-Pro Irons Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
View Most Popular
Euro-Pro Irons
  • Euro-Pro Irons
Most Popular Question
no steam comes out hasn 39 t
  • Irons
