20 Most Recent Janome MC 4400 Computerized Sewing Machine Questions & Answers
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Janome MC 4400... | Answered on Nov 16, 2017
On the back or bottom of the machine
Janome MC 4400... | Answered on Feb 03, 2014
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Janome MC 4400... | Answered on Dec 07, 2012
MY JANOME 4400 IS SKIPPING STITCHES, ITJUST STARTED DOING THIS, HELP!!!!
Janome MC 4400... | Answered on Sep 18, 2012
On my MC200e the needle is disengaged automatically when I slide the bobbin winding spindle to the right.
Janome MC 4400... | Answered on Sep 07, 2012
slide the bobbin winding spindle. if that doesn't disengage the needle... your machine may need professional servicing.
Janome MC 4400... | Answered on Sep 05, 2012
sounds like the tension dial needs to be replaced
try--sewingpartsonline.com
Janome MC 4400... | Answered on Apr 01, 2012
The 5000 series manual is listed in my site. Linda at Relics
Janome MC 4400... | Answered on Jun 18, 2011
Turn the tension up on the bobbin case. There is a small slotted screw on the bobbin case, usually at the 6 oclock position when the case is in the machine. There should be a small screwdriver in your kit. Turn the tension screw 1/2 turn and try it. No luck, try another 1/2 turn. If its no difference then set back to the original place. Sometimes junk gets jammed behind the tension plates in the bobbin case, they will cause this. A dealer may be the only solution.
Derek
Janome MC 4400... | Answered on Jan 18, 2011
Use this link to work out your model number
Janome - New Home Model Identification Code
Janome MC 4400... | Answered on Jan 13, 2010
if your using your standard universal needle, you can. just make sure your using the right number for the material
Janome Sewing... | Answered on Aug 02, 2020
The FC code refers to the (F)oot (Control) which is connected incorrectly, damaged, or defective.
Janome Sewing... | Answered on Jul 29, 2020
take it to your local service shop ans have them figure out the problem .I personally bought a seperate bobbin winder(SIMPLICITY) from joann fabrics so I DIDN'T HAVE THIS PROBLEM
Janome Sewing... | Answered on Jul 27, 2020
ASK THE MANUFACTURER OR GOOGLE IT
Janome Sewing... | Answered on Jul 01, 2020
Sewing Machines Logo
16 questions posted
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
machine missing stitches zigzag
  • Sewing Machines
