20 Most Recent
Memoq Voice Recorder - Usb Digital Voice Recorder Spy Pen, 2gb Questions & Answers
You can try using DISM:
Open Start, type: CMD
Right click CMD
Click Run as administrator
Type in at the prompt OR Copy and Paste these one at a time : (Hit enter after each)
Dism /Online /Cleanup-Image /CheckHealth
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /RestoreHealth
Also run the System File Checker utility:
Right click CMD
At the Command Prompt, type: sfc/scannow
This will check for any integrity violations
Restart your system
If the aforementioned methods fail to work, check out this article:
6 Best Solutions To Solve Double Click Folders Won't Open On Windows
Computers &...
Answered
33 minutes ago
Not a sponsor!
https://www.youtube.com/watch?v=Z3X8LzE9Uto
Computers &...
Answered
2 hours ago
If you are looking for activation support for your Netgear device via
mywifiext.net then your searching ends here. We are the best who offers benefit to Netgear customers. If you want to get benefits of
Netgear Genie Smart Setup Support then simply contact us @1-888-961-4011 and connected with our professionals.
Computers &...
Answered
11 hours ago
Notify manufacturer for assistance
Computers &...
Answered
19 hours ago
You can use the Hulu app if you have a smart tv. It might be easier to use a Roku to get access to Hulu. It is one of the easier to use streaming devices. You will need access to wireless in your house to use one conveniently. You can look up setting up a Roku on Youtube to help get you on your way. I would also suggest adding Xumo, Pluto, Crackle, Youtube, etc. since they are free.
Computers &...
Answered
21 hours ago
One of the main failures in this remote are the tactile switches. The switches can be replaced.
Computers &...
Answered
21 hours ago
never heard of WRITING THEM DOWN I assume
Computers &...
Answered
22 hours ago
n that case, you can manually "Pin to Quick access" the folders you want again.
Step 1: Open File Explorer from your computer.
Step 2: Type in the code below in the search menu and press Enter to open the recent folders.
shell:::{22877a6d-37a1-461a-91b0-dbda5aaebc99}
Step 3: Select Pin to Quick Access from the left side to pin the folders to Quick Access.
If that method fails to work, check out this article:
3 Methods To Solve Windows 10 Quick Access Folders Missing
Computers &...
Answered
2 days ago
I have this problem since last 24 hours, I spend around 6 hours to resolve this issue, visited a lot of websites, watched a number of Youtube videos to resolve this.
Finally google has redirected me to FIXYA & I got the answer. I would like to add something very important to it that, It is pretty much clear that you have to Turn off the NUM LOCK button, But the Problem is that my Keyboard doesn't have that BUTTON on the first place. So What I did. I did as follows:
In Windows Search for "On-Screen Keyboard" Click to open it.
This will open Keyboard and there is NUM LOCK BUTTON ON THE Extreme Right Bottom of the Keyboard, Just Click it to Turn it OFF.
I you do not have NUM LOCK button there then simply you have to activate NUM PAD by clicking on the OPTION buttons at the right bottom of the keyboard, and check the NUM PAD button to activate it and finally TURN OFF the NUM LOCK by clicking on it.
Thank you guys you have saved my time and resolved my issue.
Computers &...
Answered
2 days ago
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Computers &...
Answered
2 days ago
google it, learn to, answered at MS like million times now.
Computers &...
Answered
2 days ago
OE uses .dbx files, but probably not WLM. If you still have OE, try exporting your files and folders as .csr files and see if WLM can handle them.
Ah, maybe this:
The Simple Steps to Convert Outlook Express DBX files to Windows Live Mail EML File
- Download & Install DBX to EML Converter Software.
- Click on Add File Button located at Navigation Bar.
- Browse DBX files from. ...
- Click on Next, DBX to EML Converter Will automatically fetch the file from the local storage.
https://gallery.technet.microsoft.com/office/DBX-to-EML-Converter-Tool-b674a072
You can also do your own search on "convert dbx" and maybe find anther way to achieve this
Computers &...
Answered
3 days ago
then get a new phone we do not know of any fix
Computers &...
Answered
3 days ago
Welchen Markennamen hat Ihr PC-Modell? M?chten Sie eine kabelgebundene oder kabellose Tastatur haben?
Computers &...
Answered
on Apr 19, 2021
SETTING UP A SHARED NETWORK PRINTER
Any printer that is
connected to a computer and is connected on a LAN can be configured so all
other computers on the same network can print to this printer. This means the
computer with the printer attached to it MUST be booted up at all times when
other computers want to access the printer.
You need to install the
printer driver on the computer and configure it as a Shared printer.
The other computers on the
network need to add this printer to their computer.
Follow these steps to
set-up a shared network printer -
1. Connect the printer to
the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click
Share this printer, and then if you wish you could change the
Share name, then click OK
3. Right click on the
printer - click Properties - click Print Test Page to confirm printer
installation.
configure the computers on your network :-
1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached
to another computer - Next.
2. Select Browser for a
printer - Next
3. Click on and expand the
Microsoft Windows Network down to the computer with the printer - Next
4. Select Yes for - Use
this printer as the default printer - Next - Finish
5. Right click on the
installation.
Computers &...
Answered
on Apr 18, 2021
Follow the Methods below and check if that helps.
Method1:
Please follow the steps to run System Maintenance troubleshooter on the computer:
1. Type "Control Panel" on the search box.
2. Click on Troubleshooting.
3. Click on View all option on the left side of the Windows.
4. Click on System Maintenance option.
5. Click on Next and follow the onscreen instructions to troubleshoot the issue.
Method 2: Run hardware and Device troubleshooter
1. Click on the Start button, and type "Troubleshooting" on the search bar.
2. Click on troubleshooting, then click on "Hardware and sound".
3. Under Hardware and sound, click on "hardware and devices".
4. A pop-up will appear, click on the "Next" button and your hardware troubleshooting will start.
If the two methods don't work, you could refer to this article for more methods:
6 Solutions to the External Hard Drive Takes Forever to Load Issue
Computers &...
Answered
on Apr 18, 2021
The Proscan PBTW274 smart watch does not have a memory card slot. There may be a memory card slot (SD, microSD) in the smartphone/tablet that you have synchronized with the smart watch. If you have a memory card in that phone, then you can use the smart watch app to send photos directly to the SD card instead of the main memory of the phone. The only documentation for the PBTW274 on the product site,
https://www.curtisint.com/product/pbtw274/ , is in French. That manual is here:
http://legacy.curtisint.com/html/CustService/Manuals/Smart%C2%A0Watch%C2%A0Manual-PBTW274%20French.pdf .
I hope this helps. The manual jumps from the brief mention of the watch features to a long list of tools in the app. I found it unclear at first,as well.
Computers &...
Answered
on Apr 17, 2021
