20 Most Recent LG VERIZON VX5200 Hands-Free Headset (Silver) 98323 / AAYN4264A / 22802H Headset Questions & Answers
the default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
LG VERIZON... | Answered on Jun 05, 2010
you should be able to press one of the buttons under the word unlock to unlock it then to program it you will need to pair it the phone the phone has a bluetooth menu which will say discoverable or something to that effect visible press it then put the hands free in pairing mode by pressing the button under pair or sometimes holding down the button til it says to pair or gives a strange series of beeps depending on the model then on phone hit serach for devices and thenit will ask for a password on both type 0000 and then its set up you can toggle on and off through the hands free option in your phones menu or if by any chance it gives a dial pad dial *228
yes yes u can
LG VERIZON... | Answered on Mar 03, 2010
if it got wet, you can put it in a zip lock bag with rice and the rice will take the moisture out of it,
LG VERIZON... | Answered on Feb 19, 2010
http://www.fixya.com/support/r3771170-phone_water_damage
LG VERIZON... | Answered on Jan 08, 2010
On the EnV, dial *228 and select option 3. This is a relatively new feature which allows you to switch handsets anytime you wish. Follow the directions and you should be able to deativate the EnV and activate the Voyager.
LG VERIZON... | Answered on May 02, 2009
i found a voyager and i cant unlock it send me the hidden code that unlocks the phone please i know the code for atnt and tmobile but not verizon
LG VERIZON... | Answered on Mar 04, 2009
I had the same problem as the person in the original posting -- I dropped my phone after which callers could no longer here me.  So I tried dropping the phone again, as the original poster suggested, and afterwards the problem was solved.
LG VERIZON... | Answered on Feb 03, 2009
i took mine to a verizon store...they wanted me to buy a new phone
LG VERIZON... | Answered on Nov 15, 2008
try the last 4 digits of your phone number.....this should work.
LG VERIZON... | Answered on Aug 24, 2008
The system default is 0-0-0-0...
LG VERIZON... | Answered on Jun 03, 2008
ill tell you what to do if you go buy me a verizon prepaid card
LG VERIZON... | Answered on May 01, 2008
Take a piece of metal like a bobby pin and rub it on the bottom of the phone where you plug the charger in. This will reset the phone. It work for me and saved me from buying a new phone.
Good luck!!!!!!!!!
LG VERIZON... | Answered on Mar 17, 2008
there is internal damage an easy fix is to plug it into the car charger and it will only work on the charger you should have let the phone sit out and dry with the battery detatched. my phone did the same thing about 3 months ago. if that doesn't work you'll need a new phone
LG VERIZON... | Answered on Feb 13, 2008
They have different music kits for different phones. You may have gotten the wrong kit from the verizon people. You might want to go back there and ask them if you have the correct kit.
LG VERIZON... | Answered on Nov 18, 2007
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
LG Radio... | Answered on Jun 14, 2019
Radio Communications Logo
Popular Tags
23 questions posted
Top LG Radio Communications Experts
Muntejaya Ginting
Muntejaya Ginting
matt
matt
Andrew Taylor
Andrew Taylor
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • LG Radio Communications
Most Popular Question
toilet ooopsie
  • Radio Communications
