20 Most Recent LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW 16x6x16x DVD-R/RW 40x24x40x CD-R/RW 5x DVD-RAM 8.4GB 4x +... (ODDWG4163O) Burner Questions & Answers
I have supermulti dvd writter but they not read
the dvd writer must be old or lens may have moister. So try to use lens cleaner or change the writer.
it may be beacuse of one more reasons DVD you are using must have lot of scratches.
1/2/2011 11:39:50 AM • LG Super-Multi... • Answered on Jan 02, 2011
Where to find a CD-R longer than 80 minutea and
You can't, that is the maximum for a CD-R or a CD+R = approx 700Mb capacity.
DVD-R and DVD+R have a capacity of 4.5Gb
Depending upon the type of data files you want to burn, there are compression techniques you and apply and then burn them to a CD.
For example you can convert CDs to mp3 music files and burn them onto a CD-+R disk. You can fit 12 to 16 CDs albums in mp3 format on a single CD-+R disc, but your CD player needs to be a MP3 player to play these music files.
11/26/2010 4:00:47 AM • LG Super-Multi... • Answered on Nov 26, 2010
I cant get the software to install it.bought it
I would suggest you download a driver detective on your computer. Once you install this driver detective on your computer, it will help search for the correct driver for your Burner and it will automatically install it.
Connect the burner to your computer first, then install and run the driver detective.
You can download the driver detective from the below link:
http://www.drivershq.com/
Read all information before downloading.
Good luck.
8/13/2010 3:50:25 PM • LG Super-Multi... • Answered on Aug 13, 2010
My lg dvd drive is not play, not play means slowly
first ,use safe disks,then check the lens.maybe it need to cleaning.
8/11/2010 8:33:26 AM • LG Super-Multi... • Answered on Aug 11, 2010
2answers
Need to download programe
6/6/2010 1:56:19 PM • LG Super-Multi... • Answered on Jun 06, 2010
2answers
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
6/8/2009 1:06:01 AM • LG Super-Multi... • Answered on Jun 08, 2009
HELP!!!!! : "Not found CD/DVD Writer driver"
This could be due to a common issue. I would suggest you try this method first.
The following is a link to the Microsoft documented solution for issues with DVD/CD drives, explaining a step-by-step procedure. In the event that the first process, which is automated labeled "Fix It" does not solve your problem, please continue to the end of the document.
http://support.microsoft.com/kb/314060
After completing this procedure, please let us know if you are still experiencing any issues by posting a comment. If this information was helpful, please take a moment to rate the solution. Thank you
5/17/2009 6:55:33 AM • LG Super-Multi... • Answered on May 17, 2009
I put this dvdram in my computer and it is not picking it up
why u r not tried with nero image burner??? its gud and i think no need of any additional driver...chk it out still nt getting solution then tell me?
4/7/2009 4:24:50 AM • LG Super-Multi... • Answered on Apr 07, 2009
My lg external drive wont open what to do?
Dear lovableblond,
Please try to use the EJECT button from the software, or from My Computer, right click over the driver, and choose EJECT.
I hope this was helpful.
Have a good day.
Regards,
W.
3/21/2009 7:44:34 AM • LG Super-Multi... • Answered on Mar 21, 2009
Cannot back up DVDs on LG Super Multi 20x DVD rewriter
You definitely should call LG--your new gaget isn't working, and it is under warranty. Or try going to their website to see if they have any software upgrades--sounds like you have a bummer, and perhaps a reinstall from their website will do the trick.
7/3/2008 7:35:32 PM • LG Super-Multi... • Answered on Jul 03, 2008
External Drive
sounds like you broke something internally, and it is shorting out when you turn it on. I would suggest properly disposing the drive and buying a new one, as external drives are not worth fixing, and if it has a burning smell it is most defiantly a fire hazard.
3/8/2008 4:16:46 AM • LG Super-Multi... • Answered on Mar 08, 2008
Problem in DVDWriter
try new ide cables ok
2/6/2008 4:09:53 PM • LG Super-Multi... • Answered on Feb 06, 2008
Drive won't open
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
1/2/2008 8:41:29 PM • LG Super-Multi... • Answered on Jan 02, 2008
LG WD80490 When I remove plug from wall and insert again, I hear a single high pitched beep then nothing happens when I press the start button.
This could be due to a faulty start button, a problem with the wiring, or a problem with the control board. It is best to have a qualified technician inspect the appliance to identify and repair the issue.
4/2/2023 3:22:27 AM • LG Computers &... • Answered 5 hours ago
2answers
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
2/21/2023 10:34:59 PM • LG Computers &... • Answered on Feb 21, 2023
2answers
My lg dm 7630 hifi keeps going to sleep mode without me doing anything.......what should i do to fix the problem
Hi, Please record the amount of time that it takes until your device goes into sleep mode and set a timer for 5 minutes less than that time everytime you begin to use the lg device. At the points the timer/alarm goes off, you can simply lower/increase the volume and the lg's internal sleep timer should be reset. Thank you.
12/6/2022 5:25:07 PM • LG Computers &... • Answered on Dec 06, 2022
LG23MP55 IPS Monitor - HDMI Mode - All Buttons Non-functional except Power On
Hi, Please try using an alternative connection to the hdmit and test the monitor buttons again. And using analog mode prior to testing the monitor buttons again sounds like a good test as well. Thank you.
11/16/2022 10:51:37 PM • LG Computers &... • Answered on Nov 16, 2022
The nozzles orange behind the water dispenser assembly. What are they for in the LG washing machine?
'the nozzles orange'? Do you means 'orange nozzles', or is 'orange' a typo? There should be no oranges back there :>) It you have removed the dispenser drawer, the nozzles cause the water to flow into the correct compartments. You can check parts diagrams to identify any part. Please always include FULL make and MODEL in all questions. https://www.google.com/search?q=lg+washing+machine+parts+diagram ..
11/13/2022 6:01:20 PM • LG Computers &... • Answered on Nov 13, 2022
Computers & Internet Logo
20 questions posted
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
help not found cd dvd writer
  • Computers & Internet
