20 Most Recent
Mach Speed MK8-939A (VIPERMK8939A) Motherboard Questions & Answers
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
My tablet is stuck on the start up screen.
The BIOS information is typically found at or near the top of the POST screen for a very short time
ALR PC non / PCI =CTRL+ALT+ESC
AMD advanced micro devices=BIOS = DEL
Award BIOS = DEL
Dtk Datatech Enterprises Co. BIOS = ESC
Phoenix BIOS = CTRL+ALT+S
Phoenix BIOS = CTRL+ALT+INS
Restart your computer
during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS
if you have changed any of the BIOS settings by mistake
you can load failsafe or optimised defaultsusing the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
this will reset your cmos
Motherboard specs
Hi dwman113,
Yes your Mach Speed MB will support 2x1 GB, Dual Channel Mode DDR2-800MHz, PC6400 memory modules. (Manual states the memory dimms should be paired).
Also known as matched memory.
Max Shared Video Memory is 256MB, refers only to the integrated built in video card.
Click this link to help you understand what CL stands for; http://www.hardwaresecrets.com/article/26/3
Small example. CL3 runs faster than CL5.
You can run any PCI-Express 16x graphics card & it can be rev 2.0. Graphics cards are backwards compatible which means it will also run at v1.0. You should not buy a SLI card because you only have 1 PCI-E x16 slot. To run SLI, (Hooking up 2 PCI-E x16 cards together viva a small SLI connector) your motherboard would need two PCI-E x16 slots & the board must support SLI mode & your's does not. Here is the main web site link for your Mach Speed MSA2-6100V MB.
http://www.machspeed.com/specs/viper/MSA2-6100V.html
If you have any more issues or questions just post it & we'll go from there.
Good luck dwman113!
Mike
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
