20 Most Recent Konica Minolta PRINTING - Bizhub-250 Minolta 25ppm Printer/Copier/Scanner/Fa Questions & Answers
replace the fuser unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
This has to do with the tray on the finisher. Make sure it is seated in place and no paper is in it. It must cycle up and back down freely. It should reset by turning the machine off at the main power switch in the back, NOT the control panel.
Konica Minolta... | Answered on Jan 17, 2018
check behind the paper draws and remove the paper jammed back there
Konica Minolta... | Answered on Dec 30, 2015
What do you wan to recalibrate a Bizhub 250 B/W machine????
Konica Minolta... | Answered on Dec 29, 2015
take everything out of the feeder and off the glass open and close the lid and make sure that the sensor that tells the machine the lid has been opened is not stuck if that dosnt work reboot the machine
Konica Minolta... | Answered on Aug 18, 2014
We sell new konica equipment that has those features. this will replace your old BizHub 250 www.discountcopiersinc.com [email protected]
Konica Minolta... | Answered on Jun 24, 2014
enter service mode stop 00 stop 01 and than enter sop 0 c and there it shows administrator reset just enter the paswword you likce.
Konica Minolta... | Answered on Jan 27, 2014
Change the developer and verify the OPC drum and the carge corona combs.
Konica Minolta... | Answered on Jan 03, 2014
C 0202 - 1 st tray lift up failured.
Remove the 1 st tray,in the right side located 1 screw and in copier is a paper when blocated the tray lift gear.Remove the misfed paper and push in the tray ,open and closed the right door and the copier must be ready.
C 0204 - 2nd tray
C 0206 - 3 rd tray
C 0208 - 4th tray
C 0211 - bypass tray
Good luck.
Konica Minolta... | Answered on Feb 14, 2013
If the blurring is slight, it could need a deep cleaning of the glass on both sides and/or mirror assembly. A tech would probably need to do this as it requires tools. If it's severe, it could be the mirrors or the image sensor itself. Again, I'd have a tech assess the issue.
Konica Minolta... | Answered on Feb 03, 2011
22 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
blurred pictures when scanned
  • Office Equipment & Supplies
