20 Most Recent Marantz SR4600 Questions & Answers
When i on marantz sr4600 it flashes check dsp rom, plz help me with this issue
The one that is heating up and shutting down could have a shorted output. Try removing all the speaker wires. If it still heats up and shuts down, it probably has a bad output stage. On the one displaying the DSP ROM error, you may want to try a factory reset. using the following sequence: Should the operation or display seem to be abnormal, reset the unit with the following procedure. The SR4600 is turned on, press and hold the 7.1CH INPUT and ATT buttons simultaneously for 3 seconds or more.
1/18/2015 1:27:18 AM • Marantz SR4600 • Answered on Jan 18, 2015
0answers
manual
The wrong button was pushed
The 'wrong' button?? Would it be one that switches the remote to talk to a different device?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR4600-Receivers-manual/id/511dj793/t/2/
Then treat it like a new installation and guard the remote from unintentional key presses.
Look at every indicator on the receiver and evaluate what they mean and if/how they could affect your symptom.
Start at Page 7 to understand the remote.
5/12/2011 11:38:38 PM • Marantz SR4600 • Answered on May 12, 2011
Surround spkrs and sub working.
Is the speakers A turned on? Marantz in prologic mode?
2/27/2011 10:11:29 PM • Marantz SR4600 • Answered on Feb 27, 2011
Standby light is on but
Check the speaker wires for a short. If it does this with the speaker wires unhooked, it is in the receiver.
2/26/2011 3:20:11 AM • Marantz SR4600 • Answered on Feb 26, 2011
Audo none at-70 to -10
Seems that amplifier circuit is damaged.Please do continuity testing on the board to find the circuit has volts pass in and out.If so, then replace the board alone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
1/25/2011 1:08:25 PM • Marantz SR4600 • Answered on Jan 25, 2011
0answers
0answers
Marantz sr4400 a/v reciever. displayes error code
Error code POWV5 refers to a problem with the 5 Volt dc supply to the Digital/Audio PCB. If it's not a loose conection then the Main PCB is normaly the problem.
12/29/2009 11:26:31 AM • Marantz SR4600 • Answered on Dec 29, 2009
I need the codes for
I can not program my marantz remote to my element tv or my denon dvd player
2/8/2009 3:45:01 PM • Marantz SR4600 • Answered on Feb 08, 2009
2answers
Can't get receiver out of "protect"
You have a problem in the main power supply or the output circuit in this reciver. If you have any solid state repair experience, go inside and unsolder or take out the main output devices, and try to turn on the unit. If it still does not come on, your going to need to troubleshoot the power supply. If it does come on then the output devices you took out are bad. If you have no training in this stuff, seek out a pro to assist you in this repair. There are no user replaceable parts inside these units. Good Luck
9/12/2007 1:21:24 PM • Marantz SR4600 • Answered on Sep 12, 2007
Marantx SR4600 Receiver
Some indication of power supply issue. if it is 6 months old. It should be still under warranty. Should it not?
9/7/2007 2:37:51 PM • Marantz SR4600 • Answered on Sep 07, 2007
Marantz sr18 sound goes out
NOT A CAR/TRUCK SO MOVED TO AVR THE AVG. AVR HAS OVERLOAD DETECTOR AND LAMP AND RELAY THAT FAILS WHEN OVERLOADED. PER THIS SIMPLE LIST
  1. SPEAKER WIRES SHORTED.ENDTO END
  2. SPEAKER SHORTED.
  3. TOO MANY SPEAKERS WIRED IN PARALLEL.(THE ohms rule violated)]
  4. the amps side is failing.
  5. the overload detector is bad, telling lies, and shutting it down.
  6. try no speakers, to see if it trips.
  7. It is 1999 and is old. even bad caps inside now.
only does Digital inputs: coaxial, optical Video Connections: component, composite, SVHS the rig has fan sensor failure and over temp too, and the service manual covers that. see protector DRIVE here, it shuts down all outputs via relays. free to read and DL. https://www.manualslib.com/manual/1066247/Marantz-Sr-18-U.html?page=6#manual
11/2/2022 9:22:06 PM • Marantz Audio... • Answered on Nov 02, 2022
3answers
Marantz pm 7200 amplifier
2002 made, a 20 year run, not bad for any old AMP.fuses good?????? yes.I got confused in the first post gee I can hear it? but yes the AMP works plays music etc, not told and only tone fails, just that, and we know why.source direct button is pushed in,OOPS now tone is dead by DESIGNif still fails we check all DC supplies to tone board 7000and clean all switch and relay contacts with electronics spray cleaner as we fully cycle each switch.or pay others huge cash (bread) to do those 2 simple acts.your call !usershttps://www.manualslib.com/manual/99021/Marantz-Pm7200.html?page=7&term=ohm&selected=3#manualservicehttps://www.manualslib.com/manual/837384/Marantz-Pm7200n1b.html
9/25/2022 7:27:22 AM • Marantz Audio... • Answered on Sep 25, 2022
Marantz SR4600 Logo
25 questions posted
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
marantz sr4400 v reciever displayes
  • Audio Players & Recorders
