20 Most Recent Nikon D50 Digital Camera with 18-55mm and 55-200mm Lenses Questions & Answers
Camara maakt geen fotos
Assuming that your camera is not broken, you may have the color balance set incorrectly. Go into your menus and find the color balance settings. Assuming that you are using the camera outdoors midday, your white balance should be set to approximately 5400 to 5600k.
1/24/2015 12:29:14 AM • Nikon D50... • Answered on Jan 24, 2015
2answers
Clock is flashing and will not take a photo
Set the date and time.
5/25/2012 10:35:50 PM • Nikon D50... • Answered on May 25, 2012
\my D50 is not following
Your lens might have an issue caused by some sort of shock or impact. Before anything just try to gently turn the focus ring on the lens while on auto focus to see if it pops back into place. Sometimes this actually takes care of the issue. Just DON'T FORCE IT. If this doesn't solve your issue then contact a Nikon authorized service center because your lens is going to need repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
7/7/2011 6:02:05 PM • Nikon D50... • Answered on Jul 07, 2011
I took alot of pictures recently..seemed to be
Sorry, no. The camera is entirely reliant on the memory card to store images.
Either the camera or the memory card is faulty. Try another known good memory card to work out out which item is at fault. If it's the camera then it needs professional repairs, if it's the memory card then buy another.
Never, ever, format your memory card in a computer or external card reader, reformatting should only ever be done in-camera with a fully-charged battery.
6/30/2011 1:40:37 PM • Nikon D50... • Answered on Jun 30, 2011
How do you install a flash bracket to a nikon d50?
Most flash brackets screw into the tripod socket on the base of the camera. If your doesn't, please feel free to reply to this post, giving the make and model of your bracket.
6/17/2011 6:01:14 PM • Nikon D50... • Answered on Jun 17, 2011
2answers
Nikon camera d50 lens 15-200mm. Showing an F-- on
F-- error message. Most of the time, this error message is limited to Nikon DSLR cameras, because its related to a lens error.
The camera is having trouble communicating with the lens. Dismount the lens, carefully clean the contacts that mate with the body, and remount it. This usually works. Check the lens to ensure it's locked into place. If you cannot make this particular lens work, try a different lens to see whether the F-- error message continues. You'll then know whether the problem is with the original lens or the camera.
In some cases, that problem it had to do with the aperture ring on the lens - make sure it's locked.
Hope helps.
5/2/2011 11:30:44 PM • Nikon D50... • Answered on May 02, 2011
Flashing "Err" message with a code 999. Can't shoot pictures.
Try resetting the camera.
First a soft reset is to just replace the battery. If that doesn't work try a hard reset - on the bottom the other side to the battery flap.
5/7/2009 8:47:08 AM • Nikon D50... • Answered on May 07, 2009
I cannot release the battery on Nikon D40X
Check out the videos. If the battery has swollen you will have to prise it out. https://www.google.com/search?q=release+the+battery+on+Nikon+D40X ..
2/1/2022 2:57:33 PM • Nikon D Cameras • Answered on Feb 01, 2022
2answers
Convert NEF format to JPEG
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
7/8/2021 3:19:13 AM • Nikon D Cameras • Answered on Jul 08, 2021
D3400 cannot turn on Bluetooth. Camera says cannot due to current settings/
Is the camera in airplane or power saving mode?
2/2/2019 10:40:21 PM • Nikon D Cameras • Answered on Feb 02, 2019
Need to know how to open my D-7300 to replace broken gear.
More info needed.
1/17/2019 9:59:57 PM • Nikon D Cameras • Answered on Jan 17, 2019
2answers
My 1 year old Nikon D7200 camera will not take a clear picture of Christmas lights unless I put it in mirror up position. .. why
By not clear do you mean out of focus or streaked due to movement? Try using a higher ISO setting in order to allow for a faster shutter speed and/or use a tripod.
8/2/2018 9:46:01 PM • Nikon D Cameras • Answered on Aug 02, 2018
Nikon D50 Digital Camera with 18-55mm and 55-200mm Lenses Logo
14 questions posted
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
nikon camera d50 lens 15 200mm showing
  • Cameras
