20 Most Recent
Polaroid PDM-0722 Questions & Answers
I can only play American Dvd´s, can I have
American DVD (refered to as Region 1)
There are hacks available, but this is your responsibility. If you hack the machine, there may be a possibility that is will not work for any DVD. Although this is rare, it does happen.
Proceed at your own risk:
http://www.dvddemystifiziert.de/codefree_en/polaroid.html
good luck and don't forget to vote!!!
9/28/2010 5:09:52 PM •
Polaroid...
Answered
on Sep 28, 2010
My DVD player plays the movie but I can only hear
when dvd players play up the first unit to burn out is always the audio point left or right to have a blow out in regards to the video output is not usual. either the output has been switched to cma or the video output has gone kaput
best of luck
9/21/2010 11:06:32 AM •
Polaroid...
Answered
on Sep 21, 2010
The DVD won't spin and
Cleaning won't help in this case, one of the possible causes could be a faulty motor, or the electronics of the drive do not work properly anymore. The drive might need to be replaced entirely, you will need to find a local dvd repairer, check the local repair directory from the top of this page. note that since a new dvd player doesn't cost much, it might cost more to repair the old one.
5/15/2010 3:23:33 PM •
Polaroid...
Answered
on May 15, 2010
Lcd display is upside down
here is the answer:
hold down the "MODE" button while a DVD is playing.
http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/std_adp.php?p_faqid=2863&p_created=1123860923&p_sid=-SRglRFi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9NDoyJnBfcm93X2NudD0zNCZwX3Byb2RzPTIyOCwzNjksNDQ4LDQ1MyZwX2NhdHM9MCZwX3B2PTQuNDUzJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTI*&p_li=&p_topview=1
7/5/2007 6:05:28 PM •
Polaroid...
Answered
on Jul 05, 2007
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
