20 Most Recent PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive Questions & Answers
The disk cannot written to because it is write
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
9/21/2018 8:39:38 AM • PQI 512MB... • Answered on Sep 21, 2018
Windows has stopped this device because it has reported problems. (Code 43)
format it , right clik on it . if u can ever get it up.
6/26/2014 3:39:45 AM • PQI 512MB... • Answered on Jun 26, 2014
3answers
MY USB FLASH DRIVE IS DETECTED BUT CANT BE SEEN ON
(Windows 7) - Control Panel - ( make Large Icons) - Folder Options - View (check "Show hiden files,folders and drives"). Then go to C:\\ and look for "Ur-Smart Data" Folder (Delete it). (That's solution!) for more contact me : [email protected]
1/10/2014 1:19:39 AM • PQI 512MB... • Answered on Jan 10, 2014
512 Intelligent stick usb 2.0 flash drive no format
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory disk / hdd to the computer , run the program.
On the program , select the dig deep option for accidentally deleted files or dig deeper for a formatted drive. Then select the disk you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the data was lost. Save the files to a location on the computer hard drive and not back to the disk it is recovering from as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
1/5/2014 2:41:27 PM • PQI 512MB... • Answered on Jan 05, 2014
What is USB error 43
This is device manager error. It means One of the drivers controlling the device notified the operating system that the device failed in some manner. You can visit this link for the solution of your problem. http://social.technet.microsoft.com/Forums/en/w7itprohardware/thread/6f40e3e8-7283-47e4-a13f-ca6c4f3fae02
2/26/2013 10:34:11 AM • PQI 512MB... • Answered on Feb 26, 2013
2answers
I cannot format my USB.
Some usb keys or flash drives have a little switch that locks it & makes it read only. Try looking for something like this. Or you try following these steps:
For USB drives:
1. Open Start -> Run...
2. type diskmgmt.msc and press enter
3. right click on the partitin you want to format (where the leter and size is)
4. select 'Delete Partition...' and confirm
5. right mose button in the same place and select 'Create partition'
6. select primary partition
6. select size, file forma, disk leter, label etc should be all right if you leave defaults.
7. click ok
This will recreat the partition and format it in proper way.
I hope this information will be helpful. Thank you for using FixYa!
7/29/2012 7:22:19 AM • PQI 512MB... • Answered on Jul 29, 2012
I cant delete files from my usb-stick. i thinks a virus is stopping me from deleting the files.can anyone please tell me what i can do?
insert drive in your computer but dont open any files. close out the screen that comes up for the drive. then go to my computer and right click on the drive one time. then you should see scan for viruses. do that to check for and delete viruses. then go and open the usb drive and try to delete the files
3/24/2012 3:50:42 AM • PQI 512MB... • Answered on Mar 24, 2012
The background on my flash drive won't open
im not sure i understand the background on your flash drive
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts hope this helps you
10/4/2011 2:31:29 PM • PQI 512MB... • Answered on Oct 04, 2011
How do i unlock my usb stick
is it password protected or you just cant access it to see it
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
8/13/2011 2:28:17 AM • PQI 512MB... • Answered on Aug 13, 2011
Windovs uneble to complit yhe format on usb pqi 8
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers if you can see your usb drive but its not working ports(com&lpt)right click update driverclick start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive click start click on my computer you should see your drive right click then select format another way is to control panel administrive tools computer management disk management right click on your drive select format hope this helps
8/2/2011 3:41:04 PM • PQI 512MB... • Answered on Aug 02, 2011
How to remove write protection on usb
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value. click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine. # Remember: do not delete any unknow files in the registry as this will make some programes not work as usual. also If you are running a Windows XP OS then you might be able to: - click start right click on my computer select open - Right click the icon of your Flash Drive (It should be F:/ or something) - Click Properties in the menu that comes up - Click the Sharing tab - Click permissions - And finally, click Allow next to Full Control. hope this helps you
7/27/2011 11:14:40 PM • PQI 512MB... • Answered on Jul 27, 2011
Hi there! I got this
You probably need data recovery help to get the data off your flash drive but first try a free program like Recuva to save your data: http://www.piriform.com/recuva
A good choice for fast remote data recovery performed over the Internet is: http://FreeDataRecovery.us
Another reasonably priced choice but you need to ship out the flash drive is: http://300dollardatarecovery.com
7/26/2011 2:33:42 PM • PQI 512MB... • Answered on Jul 26, 2011
I can't remove the mp3
Format the whole disk
7/25/2011 10:25:46 AM • PQI 512MB... • Answered on Jul 25, 2011
4 gb usb stick. I
To Whom It May Concern,
I am very sorry you are experiencing this problem. I will do anything i can do to help. From what you have said i believe there is a Virus. Please do a Virus scan.
Thanks,
FixYa Expert
****Please Rate Thumbs Up if you like my Solution****
7/16/2011 5:06:22 PM • PQI 512MB... • Answered on Jul 16, 2011
I want to format my
On a Windows XP-based computer, you cannot format a Memory Stick removable media device by using the FAT32 file system because there is no option to for FAT32 in the Format Local Disk dialog box. The only available option in the File system list in the Format Local Disk dialog box is FAT
So that you can use NTFS option to your HDD and then format the removable media device
3/22/2011 2:03:55 PM • PQI 512MB... • Answered on Mar 22, 2011
I can't format my flash
alsoIf you are running a Windows XP OS then you might be able to: - click start right click on my computer select open- Right click the icon of your Flash Drive (It should be F:/ or something) - Click Properties in the menu that comes up - Click the Sharing tab - Click permissions - And finally, click Allow next to Full Control.
hope this helps don
2/18/2011 2:42:20 PM • PQI 512MB... • Answered on Feb 18, 2011
0answers
PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive Logo
56 questions posted
Top PQI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PQI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PQI Computers & Internet
Most Popular Question
usb flash drive detected but seen
  • Computers & Internet
