20 Most Recent Supersonic SC-299TDVD Questions & Answers
vendo mi dvd player solo no funciona con el control pero se puede arregla
Supersonic... | Answered on Feb 12, 2014
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is the cause of he problem and not battery.
The lens reads the files/data on the disc inserted into the player and once the lens is weak, there is no way it would load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all CD's with no problem at all.
Good luck.
Supersonic... | Answered on Apr 22, 2010
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Supersonic... | Answered on Aug 15, 2008
sounds like a faulty Backlight.. If you just bought this take it back and get it replaced, Check if the Manufacturer's warranty is still valid. if this was bought second hand (out of warranty) I would take it back. as it is unlikely that the prev owner did not know of this issue.
Supersonic... | Answered on Nov 04, 2007
Please read all of this before you do anything since my last suggestion may be the place to start.
This means it "needs" to do this in order to find the OTA (over the air) TV channels which have recently changed. Go through the menu system & possibly Tools to find the auto channel scan and let it do that.
I don't know why it would ask you to do this unless you also have the TV attached to the Internet, then it would know it needs this new channel scan, but I have four TVs in the house and none of them told me they needed a new scan. I knew this because I keep track of what is going on with OTA TV channels.
So, let's assume you've done the scan again, you also say you don't know how to get it back to monitoring your camera.
Once the channel scan is done it may be happy and simply find your camera again. If not, your camera probably came with instructions on how to set it up in the first place, find those and find how how to attach it to the TV again.
If you've lost those instructions look up the make & model of the camera on the Internet to see if you can now download the pdf version of the user's manual and/or setup instructions.
LAST: You may want to try this first: Most remotes have a button called "Input" or "Source" look for that button. With the TV on & pointing it towards the TV press the remote "Source" button, look at all the input sources it has & go through them one at a time and then wait for something or nothing to come up. One of these sources may be your camera.
Supersonic... | Answered on Aug 11, 2019
You can look at this site and see if they have one. https://www.manualslib.com/
Supersonic... | Answered on Mar 29, 2019
Supersonic SC-299TDVD Logo
13 questions posted
Top Supersonic Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Kardoc
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Supersonic Televison & Video
Most Popular Question
dark screen
  • Televison & Video
