20 Most Recent Tatung WM42HDMT Television Questions & Answers
Usually wall mounts are the same for all units. The only thing to be considered is the size of the screen. Being that your screen is a 42inch you might want to go for a mount which is suitable for that size. Prescribing a particular type might only make you spend more because getting it to your location might cost more. Just get anyone which is made of steel.
Hope this solution has been helpful?
Tatung WM42HDMT... | Answered on Jun 26, 2011
Does your television have pc/vga input. because it has to have that to connect to a pc,,or unless you have installed another video /graphics card with other inputs,,if so make sure u have drivers for the windows os you are running,,good luck
Tatung WM42HDMT... | Answered on Nov 18, 2010
hi there, i need to know what type of antena i have to buy for tataung tv model no: P42BSMT year:2005 .do i need any thing else to get the tv started? i really appreciate your reply . Thank you . Sakib .
Tatung WM42HDMT... | Answered on Jun 03, 2010
Televisions that lack high definition will neither need nor have HDMI capability. Older televisions will not require the 1080p connection that HDMI provides. If yourtelevision is not a flat screen, LCD or plasma, then it will not have HDMI capability.
Tatung Televison... | Answered on Feb 16, 2019
www.publiphone tatung.com/
Try this link.
Tatung Televison... | Answered on Aug 24, 2015
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Tatung Televison... | Answered on Jun 07, 2015
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations.
Tatung Televison... | Answered on Jul 30, 2014
Check the cables and connections
Tatung Televison... | Answered on Apr 13, 2014
If you have 3 capacitors bad, there are likely more that you missed.
You didn't mention what kind of Flat Panel. If LCD, then check for the 5 volt supply. The caps are likely 220uF and 1000uF - 1500uF and all in the 16 volt range.
Tatung Televison... | Answered on Nov 08, 2013
Tatung WM42HDMT Television Logo
Popular Tags
5 questions posted
Top Tatung Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
MrFixitSTTL
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Tatung Televison & Video
Most Popular Question
am having issues external speaker setup
  • Televison & Video
