20 Most Recent Konica Minolta Fusing Unit Bizhub C252 C250 4038075400 Questions & Answers
I searched the internet using https://www.google.com and found the following result, that may require a technician to resolve:
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20C368&code=C5360
Code
C5360
Description
Clean unit fan failure to turn (When CU-101 is installed). The fan lock signal remains HIGH for a predetermined continuous period of time while the fan is turning.
Causes
• Exhaust fan/1 (FM14) • Exhaust fan/2 (FM15) • Suction fan (FM16) • Clean unit drive board (CUDB) • MFP board (MFPB)
Remedy
1. Check the connector between CUDB CN1-MFPB CN32E for proper connection and correct as necessary. 2. Check the connector between FM14-CUDB CN3, FM15-CUDB CN2, FM16-relay CN183-CUDB CN4 for proper connection and correct as necessary. 3. Check the fan for possible overload and correct as necessary. 4. FM14, FM15, FM16 operation check • Load check: Check code42, Multi code 4 • Control signal: CUDB CN3 (FM14), CUDB CN2 (FM15), CUDB CN4 (FM16) • Location of electrical component: 14-X 5. Replace the defective fan. (FM14 / FM15 / FM16) 6. Replace CUDB. 7. MFPB ICP14E conduction check 8. Replace MFPB.
Konica Minolta... | Answered on Feb 21, 2019
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall. Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed. Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed. If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Konica Minolta... | Answered on Feb 19, 2019
Aoc tft20w90ps driver? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
8921MYD1 715G2892 2 3 AOC ADTV8921MYD1 Power Supply Backlight Inverter for...
Konica Minolta... | Answered on Jan 25, 2015
In all likelihood this is the IH power supply board. Not a difficult procedure but the board may be expensive. Can send through details if required.Cheers
Konica Minolta... | Answered on Aug 04, 2014
Konica Minolta Fusing Unit Bizhub C252 C250 4038075400 Logo
15 questions posted
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
Tom Chichester
Terry
Terry
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Computers & Internet
Most Popular Question
error c3451 bizhub c450
  • Computers & Internet
