20 Most Recent Paradyne (6218-A1-200) Wireless Router (6218A1200) Questions & Answers
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
Paradyne... • Answered on Mar 29, 2013
Hi there, there are so many possibilities to your problem, however the first thing I would do is check underneath your router for the Ip address, if it is not there, then you can check your booklet that came with the router (assuming that you still have it of course)!!
Once you have this, you may then reconfigure / restore the router or alternatively (and firstly), I would check the network key and the type of encryption. The chances are that when you updated the firmware, that the key was also changed! Obviously make sure that the network key you are entering into your computer matches the one within the router for wireless applications, I hope this helps you, Chris
Paradyne... • Answered on Sep 12, 2011
Username: admin Password: admin
Paradyne... • Answered on Sep 07, 2011
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Paradyne... • Answered on Aug 09, 2011
There are many reasons why this might be happening.. You could try the following steps..
1) Disconnect the power from router for a minute and reconnect and check.
2) Try changing the wireless channel and Network name and try re-connecting.
3) Check if there is an firmware update for your product and update if any update is available. You can check this by visiting http://en-us-support.belkin.com/app/product/list/q/routers/ and enter your product details.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Paradyne... • Answered on Mar 09, 2011
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Paradyne... • Answered on Feb 05, 2011
read user manual you will get the information about the topic
thanks
Paradyne... • Answered on Nov 10, 2010
Paradyne (6218-A1-200) Wireless Router (6218A1200) Logo
42 questions posted
Top Paradyne Computers & Internet Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Paradyne Computers & Internet
Most Popular Question
configure port forwarding router need
  • Computers & Internet
