20 Most Recent Weather King 10AJA2501AH Air Conditioner Questions & Answers
you should have professional HVAC mechanic do this work. It is not safe, for you or the environment,to do it yourself
Weather King... | Answered on Jul 18, 2014
To be honest these manufacturers are all about the same, The differance is going to be a good install vs. a bad install. Just make sure to shop wisley when you are looking for an installation contractor.
Hope this helps Ya please rate me.
Weather King... | Answered on Feb 13, 2014
If the fan works on AC mode, then it is most likely a problem with the ignition system. There is a safety feature that shuts off most everything if the heater does not sense ignition. It could be the ignitor, the sensor, or the main control board. Look for a blinking red led light. It will give you a trouble code to start with. If you don't feel comfortable with electricity, don't mess with it. Call for professional help.
Weather King... | Answered on Nov 25, 2013
you have to take in accounts of how many windows, facing the sun, which way the house face during the day, attic insulations ,wall insulations, floor insulations, types of windows, its best to just have a professional do a load calucalation.
Weather King... | Answered on Nov 04, 2013
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
Weather King... | Answered on Sep 13, 2013
Sounds like you need to recharge it .. To tell while the unit is running go outsiode and feel the large insulated copper line going to the unit it should be cold to point od sweating like a can of coke you take out of the refrigerator and sit on the counter. also feel the air coming out of the unit outside it should be warmer than the outside air if not your freon is low
Weather King... | Answered on Jul 13, 2013
If the unit will not come on at all, it is probably either the contactor-relay or capacitor, and since I always receommend that you replace it as a set, it doesn't matter which.
Weather King... | Answered on Sep 05, 2011
Hello
Is there a low or high pressure shut off switch your missing.It may need to be reset.
Also check any freeze switches,usually located at the coil inside they may need to be reset.
Weather King... | Answered on Aug 09, 2011
Weather King 10AJA2501AH Air Conditioner Logo
81 questions posted
Top Weather King Heating & Cooling Experts
John Tripp
John Tripp
MARLON KELLER
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Weather King Heating & Cooling
Most Popular Question
air comes blows but fan outside
  • Heating & Cooling
