20 Most Recent Dacor Epicure 30" Double Wall Oven, Stainless Steel - E0230SCH Electric Questions & Answers
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Dacor Epicure... | Answered on Jul 18, 2016
Should be two screws under the knobs on front of panel
Dacor Epicure... | Answered on Oct 16, 2013
The MODEL Series you already said in your question: EO230SCH
Check and see if it is this model:
Good Luck!
Dacor Epicure... | Answered on Dec 06, 2010
Don't do it. The high temps screw up the expensive control board.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dacor Epicure... | Answered on Dec 30, 2009
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Dacor Epicure... | Answered on Sep 19, 2009
I'm sure what you are asking. If you need an element, you can order it by your model number, which you have provided. We supply parts and you are welcome to call us at 9728590929 and we will be happy to assist you with your parts orders. We hope this helps!
Dacor Epicure... | Answered on Aug 14, 2009
if you talking about you convectin fan you proably have a stuck realy in the control bd and will need to replace it
Dacor Epicure... | Answered on Feb 04, 2009
clean the air vents??? building up with dust lint and such??? the vaccuum os good try using a baby bottle brush or an old toothbrush to get al trough the grooves
Dacor Epicure... | Answered on Mar 18, 2008
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Dacor Epicure... | Answered on Jan 29, 2008
Ovens Logo
Popular Tags
29 questions posted
Top Dacor Ovens Experts
Vincent G
Vincent G
Nathan Van Boven
Nathan Van Boven
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
View Most Popular
Dacor Ovens
  • Dacor Ovens
Most Popular Question
display panel works but oven will not
  • Ovens
