20 Most Recent Dacor Millennia MOV130 Electric Single Oven Questions & Answers
2answers
Dacor Wall Oven Epicure EO130
I would call the store you bought it from or dacor as it is under factory warranty...
2/23/2022 2:05:23 AM • Dacor Millennia... • Answered on Feb 23, 2022
3answers
Display reads U60 Cooling Fan - oven won't heat
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
3/24/2020 2:59:23 PM • Dacor Millennia... • Answered on Mar 24, 2020
2answers
Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
11/1/2014 6:03:31 PM • Dacor Millennia... • Answered on Nov 01, 2014
0answers
11answers
Power was out briefly last
If not installed on a surge protector - it is likely your controller is fried from either a surge or multiple on/off attempts when it finally came on.
Replacing the controller isnt difficult... LOCATING the replacement part is.
The cost of the board and Labor will put you close to what a new oven with a warranty can be had for.
It will obviously be your call to replace or repair - my reccomendation to you is put your money toward a new unit.
CLICK HERE to select/download all the manuals for this unit in PDF format.
Thanks for using FixYa!!
9/1/2009 7:45:14 PM • Dacor Millennia... • Answered on Sep 01, 2009
Convection Over with Dacor Millennia
We have the same issue anc alled Dacor. I seems as there is a problem with the oven as it was built with a faulty or missing temp control part. They have a fix for this problem by installing a temp control kit. you need to work through the warrantee group
1/3/2008 8:41:48 PM • Dacor Millennia... • Answered on Jan 03, 2008
Dacor Oven. DTOV127. My bottom oven is working fine. Top oven- After an electrical outage, the door is locked, can't open and is flashing the locked sign and rattling terribly. What do I do?
Hi, you might want to shut the power down to the unit and then call Dacor directly to help you troubleshoot the issue. Their phone number is 1 (833) 353-5483. Thank you.
10/3/2022 8:30:20 PM • Dacor Ovens • Answered on Oct 03, 2022
Dacor ecs230sch top oven not working
old post, but this video should help find the reset able thermal fuse http://blog.applianceboards.com/installs/resettable-thermal-fuse-on-dacor-ovens/
10/28/2021 6:22:27 AM • Dacor Ovens • Answered on Oct 28, 2021
Dacor MORD203S; lower oven broil burner is coming on regardless of setting
You have a failed control, or valve. turn off the gas feed immediately. The fix is to replace the control or valve. Be sure you have the skill set if you are attempting to replace the control or valve yourself. A mistake could seriously hurt or kill you.
10/2/2021 9:30:10 PM • Dacor Ovens • Answered on Oct 02, 2021
Do i really need the cooling fan to work if i have bypassed the u60 code on Dacor oven
It obviously is requesting you to replace the fan and or the relay. If it comes with the oven it is definitely needed.. Bypassing anything could cause a fire and you would lose your home. I wouldn't bypass it. Please have it repaired correctly by an authorized repairman.
5/11/2021 6:04:36 PM • Dacor Ovens • Answered on May 11, 2021
Dacor electric cookstop won't lock.
3/22/2021 7:36:10 PM • Dacor Ovens • Answered on Mar 22, 2021
Dacor bottom oven not heating
I have a DACOR double electric oven model ECD230SCH. the top oven lower element went out 1 and 1/2 years ago, but the top element broiler works. Yesterday the bottom oven did the same thing- bottom element not working along with convection. Pulled off doors and cut breaker. Checked thermal switch on top off oven- closed good. Pull out element and Ohm'ed out- good. Now pulled over and out oven top panel to get to the control boards. Found a nice set of schematics for the over control boards and electronics. Sat down and pin-pointed both relays that supply power to upper and lower oven "lower" heating elements. these are on 2 different boards- upper over relays on bigger board on the left with the transformer. Lower oven on the right smaller board. Hardest pain in the rear was just getting the little plastic stand offs to push back through the board to get it off. Finally got it off and inspected board. Low and behold the relay I pin-pointed had a burn/open connection on the solder joint. Re-soldered tested oven and lower oven lower heat element works now! Went to the next board and got that off and same exact problem on the rely for the top oven lower element. Re-solder and test- good!! Put everything together and ran over to 350 on top and lower and back to normal. Wife very happy she did not have to pay a repair man big bucks to swap out the control boards- would have had to replace both. I have a degree in electronic technology so as a technician for many years did low and high voltage component level repairs. But pretty easy and you can visually see the open solder joint on the back of the board at the relay leg. Jim B Roseville, CA.
11/15/2020 11:14:12 PM • Dacor Ovens • Answered on Nov 15, 2020
Dacor Millennia MOV130 Electric Single Oven Logo
Popular Tags
15 questions posted
Top Dacor Ovens Experts
Jaime Hernandez
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
View Most Popular
Dacor Ovens
  • Dacor Ovens
Most Popular Question
dacor wall oven epicure eo130
  • Ovens
