20 Most Recent Dacor Integrated Ventilation System - IVS1 Kitchen Hood Questions & Answers
92348 is the part number for that lamp.
Dacor Integrated... | Answered on Jan 07, 2012
You need the suction bulb that came with the unit.  In case you do not have it, it is part #62408 and is about $2.00.  I am trying to figure out for myself how to get the lens cover off in order to access the bulb, and how to replace it when the new bulb is put in.
Dacor Integrated... | Answered on Jun 07, 2008
Most gas stoves come from the factory ready for natural gas service,as most of the world is piped for natural gas when gas is used as a fuel,but they are easily converted to LP ( liquified petroleum) gas by installing a conversion kit. As this gas is very explosive I wouldn't recommend a homeowner tackling this job themselves,but hire your gas supplier to do the conversion or a licensed contractor.
The added expense of hiring a licensed contractor is far cheaper than loosing your home and possibly serious injury or ***** to family members because of a botched conversion job.
Dacor Kitchen... | Answered on Nov 14, 2019
The element may show continuity (should be very low ohms) however when he element heats up it will open and no longer heat, when it gets cool enough it will heat again and cycle will repeat. I would look at high limit switch while I had it apart. The only true test to verify element is not heating is using a clamp on current meter.
Dacor Kitchen... | Answered on Feb 12, 2019
use some packing tape stick it on light lens to turn
the hood came with a suction cup for unscrewing bulbs
you could order through dacor or find one in dollar store
Dacor Kitchen... | Answered on Jan 20, 2019
yes the cooloing fan runs when oven is turned on and should be set to continue running after oven is turned off
it should be set to run until oven drops below 300 deg f
this can be changed if not set correct
Dacor Kitchen... | Answered on Sep 21, 2018
you should remove burner nuts and lift cook top as the plastic console has a lip that sits under cook top
good luck with touch pad very unusual unless light flickering on and off
Dacor Kitchen... | Answered on Feb 05, 2018
Kitchen Ranges Logo
Popular Tags
3 questions posted
Top Dacor Kitchen Ranges Experts
Ekse
Marvin
Marvin
Paul Carew
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Dacor Kitchen Ranges
Most Popular Question
part number davor ivs1
  • Kitchen Ranges
