20 Most Recent
Alfa Network Alfa UBDo-nt8 OUTDOOR Wireless USB kit w/ 12 dBi antenna Questions & Answers
Descargar drivers de alfa alfa ubdo-nt8
google translated spanish to englishdownload driver alfa alfa-NT8 ubdo
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution note: it will find all of your outdated drivers This is a free driver solutions. This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Hope this helps
Failure the connectivity
Check that your USB connection is not loose, and if still having connection dropping, try a new or different USB cord.
Last solution: re-install the drivers.
Attention! this is a 32-bit driver, and it will NOT work with 64 bits OS (Win 8 and above, Mac OS X Lion and above)
The UBDo-gt8 has an Realtek RTL8187L chipset, and it is an excellent one,
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
