20 Most Recent Eton E100 SW/FM/AM Radio Questions & Answers
Slightly off frequency is it possible to correct
I assume it is digital tuning?If it is digital tuning the answer is no.Sometimes reception is better when you purposely mis-tune by one digit lower or higher than the stations call numbers.If it is under warranty, try exchanging it or just listen to and compare another one or more of the same model to hear if they are all slightly off frequency.
9/10/2013 6:13:48 PM • Eton E100... • Answered on Sep 10, 2013
No sound from speaker but through ear piece I get
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first. Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection. You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
9/10/2013 5:14:10 PM • Eton E100... • Answered on Sep 10, 2013
3answers
ETON webcam drivers
tung
12/4/2010 9:10:57 AM • Eton E100... • Answered on Dec 04, 2010
ETON Webcam diriver needed for 3.0 Mega Pixal Please Help Me
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/14/2010 10:19:46 PM • Eton E100... • Answered on Aug 14, 2010
I lost the cd ,so i can,t iconnecting
I did a quick search on Google and found loads of sites with info - http://www.universal-radio.com/catalog/portable/0100prgm.html this one has a list of all the functions.
11/1/2009 10:27:54 AM • Eton E100... • Answered on Nov 01, 2009
0answers
4answers
Satellite radio doesn't work
heres a list of services listed on fixya
http://www.fixya.com/Services.aspx?prdid=440173&zip=&x=16&y=19
6/18/2008 4:23:55 AM • Eton E100... • Answered on Jun 18, 2008
Memory
Hi there!
This is a problem caused by the Airport's securuty systems.
They have damaged your equipment. If you were not warned of the risk and given a chance to avoid being scanned, then you should be entitled to some compensation for the damage.
Contact the airport customewr services. They should be able to advise you from there.
I hope you get some compensation for it.
6/17/2008 11:38:25 AM • Eton E100... • Answered on Jun 17, 2008
Eton Microlink FR160 Emergency Solar Powered Radio. Do I need to change the battery? How will I know it is time to change it?
Question edited for clarity and add CAPS. Yes the battery has a certain number of charge / discharge cycles. You will know when because you will spend more time winding it up than listening to it, or the flashlight lasts 2 minutes. Batteries are available via Amazon. https://www.google.com/search?q=eton+radio+microlink+fr160 ..
3/22/2024 2:52:31 AM • Eton Audio... • Answered on Mar 22, 2024
Why Eton Elite has no volume or signal?
Batteries are flat or the AC adapter has failed? https://www.manualslib.com/manual/1946294/Eton-Elite-750.html#manual ..
4/11/2022 6:03:38 PM • Eton Audio... • Answered on Apr 11, 2022
Eton elite mini radio won't turn on with the power button. The "on" displays for a second and then disappears.
1. Defective power button 2. Defective power supply
12/1/2020 2:38:04 AM • Eton Audio... • Answered on Dec 01, 2020
The crank on my Eton FR250 feels to have less weight when turning and it does not charge the battery. I changed the battery and still no difference.
Are you having problems with the engine turning over when you attempt to start it? There's a possibility that the starter could be having problems. If you can provide more information, that would be helpful. Thanks.
6/2/2016 3:56:44 PM • Eton Audio... • Answered on Jun 02, 2016
0answers
Eton E100 SW/FM/AM Radio Logo
10 questions posted
Top Eton Audio Players & Recorders Experts
k24674
John
John
ADMIN Andrew
ADMIN Andrew
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Eton Audio Players & Recorders
Most Popular Question
no sound from speaker but ear piece get
  • Audio Players & Recorders
