20 Most Recent AEG 24 in. Favorit 40650 Free-Standing Dishwasher Questions & Answers
Can't pull one up online under the manufacturer Favorit?
AEG 24 in.... | Answered on Apr 22, 2014
When this happened to ours it was food debris in the water supply feed. There is a tank located in the left hand side wall which is accessed by taking the side off the machine. This tank needs to be replaced as although it may reset itself a few times the problem continue to occur until the water fill path is clear
AEG 24 in.... | Answered on Mar 02, 2014
The dishwasher has an outlet pump in line with the outlet hose. This pump must work in order for the washer to drain. The pump can be tested by unpluging it and removing the 2 hose clamps. Connect the pump to the mains for a few seconds and it should spin the impeler. The impeler must rotate a a speed and must not be obstructed in any way. If this does not spin the outlet motor it should be replaced.
AEG 24 in.... | Answered on Jan 20, 2010
On the 40660 washer this element is in line with the top sprayer arm pipe and is at the back bottom of the washer. Easly reachable by removing the back bottom plate. Has a clamp on each end and a electrical push on connector.
Check the element by using an Ohm meter. You should get an ohm reading if the element is OK. If the element is open circuit you would get an infinity reading. Just note that "newer" machines do not use the traditional heating elements but do have a (Inductive heater) coupled in line with the hose feeding the top spray arm of the washer. This unit must be cheched by a dealer as a DIY will have dificullty checking it.
AEG 24 in.... | Answered on Jan 19, 2010
Thanks. I figured it out from the online manual. Hold buttons #2 and #3 (second and third button down on far left side) for 2 seconds should reset it. It took some 15 minutes however before the dishwasher reset!
Peter Smith
AEG 24 in.... | Answered on Jan 28, 2009
We had this a while back on ours. For us it meant that the flood prevention system had kicked in. I took the metal panel at the bottom at the front off and sucked out water with a syringe until it started working again. We think the problem was that something was blocked with grease so ran a hot cycle with a Finish cleaning cartridge in.
AEG Dishwashers | Answered on May 09, 2019
Google or request from manufacturer
AEG Dishwashers | Answered on Mar 05, 2019
I guess you got the alarm AL 6 on your display what means failure to drain. A control procedure has been added to all the final drain phases in order to check the status of the pressure switch. The contact must be open in the "empty" position in order to ensure that the cycle is performed correctly. If the contact is closed, the drain phase is repeated. At the end of the second drain phase, if the pressure switch contact remains closed, "AL" alarm condition is generated.
Could be following:
  • Domestic drain circuit not suitable (obstructed / blocked)
  • Drain pump jammed
  • Pressure switch faulty
  • Sump - pressure switch tube obstructed
  • Filters / drain hose obstructed
  • Relay or Triac faulty
Down under is from AEG Favorit 86460 user manual, page 30 :
...a flashing fault code appears
an audible signal informs you that an alarm has been activated, in the display appears one of the following flashing alarms: AL1 - AL2 - AL3 - AL4 - AL5 - AL6 - AL7, AL8 and the indicator light of the phase under way is flashing. They are indicative of a fault in the dishwasher that you can probably rectify yourself.
- press the On/Off push button to switch the dishwasher off
- open the door and carry out the following suggested corrective actions.untitled-wdmylhxvjmokugi3zifm2oyn-2-0.jpg
Dado
AEG Dishwashers | Answered on Jan 12, 2019
check the sum pump drian valve make sure it not cog up with tash because if it block can cause the drain pump to ruin ok
AEG Dishwashers | Answered on Nov 27, 2018
AEG 24 in. Favorit 40650 Free-Standing Dishwasher Logo
Popular Tags
19 questions posted
Top AEG Dishwashers Experts
Paul Carew
Mike
Mark Brooker
Level 1 Expert
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
AEG Dishwashers
  • AEG Dishwashers
Most Popular Question
water not draining even after clean
  • Dishwashers
