20 Most Recent
Jenn-Air JDB4000A Built-in Dishwasher Questions & Answers
Broken latch on the door.
That is not that hard to fix and you can easily buy the parts yourselfonline...the new parts often have installation instructions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Onlineheatman101
9/20/2010 12:50:46 AM •
Jenn-Air...
Answered
on Sep 20, 2010
Cleaning agent not being released as compartment door not opening
For verifining the exect reson for your problem, you can start with a very simple test- Place the dish soap on the bottom of the dishwasher and run it for a full cycle. In case dishes will not become claen, your problem is with the water temp.
If dishes will become clean properly, the problem is with the detergent door that doesn't opened at time (operated by a wax motor that get its power from the timer).Maybe that by cleaning the detergent cup you will solve the problem. In case it will not -To gain access to the wax motor you should open door assembly-Find the wax motor (close to the detergent dispenser cup)and test with a multi-meter if it get power(following cycle's sequence).If it get power, you should replace the wax motor. If it doesn't get power the problem is with the timer.
Good luck !!
6/11/2006 10:02:04 PM •
Jenn-Air...
Answered
on Jun 11, 2006
WATER LEAKS UNDER THE SINK WHEN DISHWASHER IS IN
Check the connection to the drain tailpiece from the dishwasher under the sink and make sure the clamp hasn't slipped off and is tight. Check the drain hose from the dishwasher and be sure it's not split or damaged. Check the drain spur on the drain tailpiece and see if it's corroded or leaking. Check the trap under the sink as well and make sure it's not leaking.
10/17/2017 8:44:12 PM •
Jenn-Air...
Answered
on Oct 17, 2017
