20 Most Recent Mitsubishi LT-55154 55in 1920x1080 16 9 120hz Led Lcd P/N: LT-55154 - Questions & Answers
Make sure all your connections are solid. You may want to try resetting it. See Appendix B: Troubleshooting in the manual downloadable here... http://www.manualslib.com/manual/296300/Mitsubishi-Lt-40164.html#product-LT-55154
Mitsubishi... | Answered on Aug 07, 2014
It is on the firewall on a metal plate. The firewall is the backwall of the car when you lift up your bonnet (hood). It should have your chassis number and engine number and paint code on it.
Mitsubishi... | Answered on Aug 23, 2019
Mitsubishi Electric NR-MZ50 Car Navigation System $1800 !
WHAT CAR? and YEAR<, go to MFG. web sit and get the manual first, if LOST ! IT.
What makes you think it can?>
sure hope.
WHA
open glove box and RTM? yet, unstated car.
car radio, head- in's/nAV are very dumbb(sic) as class of devices.
they only allow a limited set of formats.
you'r talking about movie file formats 100s,
The movie file, formats to try are MP4 and MKV (most common)
The manual Mz50. first. it will tell you what it supports, and no 2 car-heads work the same or have same limits,
so that means RTM read the manual then do experiments.
also some HEADs may have DRM rule limits.
that car HEAD really is not a computer, so is off topic here.
the MZ50 tuner can record to the SD card.
why not just try it.
find a small mp4 movie, and put it on the card, just 1 file
and see if you can play it,
but there are 100s of formats.
talk to Mitsubishi dealer or
try these
https://fileinfo.com/filetypes/video
It many do 1 or 2 but NEVER ALL formats.
Mitsubishi... | Answered on Jul 01, 2019
read the manual in the box, oops, can't
down load it ?
lost the key?
Mitsubishi... | Answered on May 21, 2019
Mitsubishi computer? What is the model number and OS.
Mitsubishi... | Answered on Jan 14, 2019
Mitsubishi is not listed with that code; Definition of check engine code P1777:
Citroen/Peugeot:
Ignition Retard Request Circuit Fault
Daewoo:
POWER CONTROL UNIT - OUTPUT MAL
Ford:
Jaguar:
Kia:
Land Rover:
Gearbox Ignition Retard Request Line Fault
Mercedes:
Torque Down Response Signal Circuit
Volkswagen/Audi:
Hydraulic Pressure Sensor 2 range / performance
Volvo:
Mitsubishi... | Answered on Nov 28, 2018
advised to buy [was those parts replaced ] and was damaged shock replaced in February or is it still damaged --your question is all over the place and confusing --------lets assume problem is now and alignment and balance was done recently bad shock -balljoints -upper or lower control arm bushings - tierods - steering rack- c/v axle --brakes any or all can cause shaking before throwing parts at it have the mechanic tell you reason part[s] need replacement and have them show you
Mitsubishi... | Answered on Nov 06, 2018
Fixya does not sell replacement cables and connectors.
Mitsubishi... | Answered on Aug 08, 2017
Hi Kristie,if your boyfriend can walk by your car and spell antifreeze,then you have a leak.Usually,it will be your water pump,you can put newspaper or whatever you can use under your car after you have driving it and wait awhile then check paper and see where it is wet to determine what is leaking,could also be a loose radiator hose which the clamp may just need tightening up,but first add some antifreeze to your over flow container,remove radiator cap after it cools down to see how much is in radiator,add if needed.Look around radiator area,it may be leaking.You can also jack it up to look.
Mitsubishi... | Answered on Jul 29, 2017
I need you to clarify what the problem is, Park doesn't hold the car?
Mitsubishi... | Answered on Jul 14, 2017
Mitsubishi LT-55154 55in 1920x1080 16 9 120hz Led Lcd P/N: LT-55154 - Logo
1 questions posted
Top Mitsubishi Computers & Internet Experts
Shaukat Bhutto
Shaukat Bhutto
John Waters
John Waters
Tom Chichester
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Computers & Internet
Most Popular Question
lt 55154 will not power led blinks four
  • Computers & Internet
