20 Most Recent Whirlpool EL02CCXP 19" Cold Pals Compact Refrigerator w/ 1.8 Cu. Ft. Capacity, Manual Defrost & Reve... Questions & Answers
I have a whirlpool ref/freezer the ice dispenser won't work. makes ice and water dispenser is ok. sv
Your model appears to be quite simple electrically. It does not have a major circuit board it's very possible that the pressure switch, wire connection at the dispenser, hinge or the interlock freezer lightswitch is bad on your model. Do you have a multi-meter/OHM meter? John T. Appliance 911 Appliance 911 Sea Breeze Here is a manual that is very close to your model http://appliance911seabreeze.com/KSBS20QEWH0%20_ED20DFXEB00_Serviice_Manual.pdf
5/21/2014 7:08:54 AM • Whirlpool... • Answered on May 21, 2014
Can a condenser on a
Only way a condensor can go bad is if leaks refrigerant or a line gets kinked. If by chance it gets clogged it can be cleared with nitrogen, it all depends on hold much service the tech knows. hope this helps.
8/11/2011 2:20:59 PM • Whirlpool... • Answered on Aug 11, 2011
Whirlpool Refrigerator - Model# ED22LF
Tom, I would start with the overload and relay that is on the compressor, If it is white it's a good possibility that it has failed. The fact that both sides are not cooling leaves me to believe the compressor is not operating. Take the overload and relay off. If they are both contained in a white cover shake it. If it rattles, I believe that is your problem. Let me know what you find...Catriver.
2/10/2009 10:12:34 AM • Whirlpool... • Answered on Feb 10, 2009
Where is the filter on the Whirlpool refrigerator #WRF535SMBB00
Where is water filter on WRF535SMBM00
7/24/2021 12:19:22 PM • Whirlpool... • Answered on Jul 24, 2021
I have a brand new whirlpool refrigerator and it buzzes but when I open the doors it quits buzzing- what is the problem??
If it is new call to get it fixed, should be free.
7/13/2021 6:06:21 PM • Whirlpool... • Answered on Jul 13, 2021
2answers
My fridge tripe the earth leakage everytime I switch on the fridge.
call ana accredited electrician to check the insulation of the wires and for vermin infestation that is across electrical connections it could be a faulty capacitor or failed motor as the earth leakage breaker is also a fuse for excessive current draw
7/11/2021 9:53:13 PM • Whirlpool... • Answered on Jul 11, 2021
Where is water filter on WRF535SMBM00 WHIRLPOOL
There is no water filter in the WRF535SMBM00 refrigerator. Whirlpool manuals often cover several models in one document. If there were a water filter in this unit, it would be above the uppermost shelf on the right-hand side of the refrigerator compartment. The water filter comes with refrigerators with a water dispenser, not just an ice maker. None of the parts diagrams show a water filter. See https://www.whirlpoolparts.com/Shop-For-Parts/a4b5d1414630/Model-WRF535SMBM00-Whirlpool-Refrigerator-Parts . I hope this helps. Cindy Wells
7/1/2021 4:33:08 PM • Whirlpool... • Answered on Jul 01, 2021
Whirlpool refrigerator evaporator keeps freezing up. Please help!
you need total professional help with it the control board has failed you and if not fixed correctly and soon your compersser will fail as mine did
6/14/2021 4:22:45 PM • Whirlpool... • Answered on Jun 14, 2021
Whirlpool k40 ice machine keeps blowing pipe off inlet valve
clamp it
6/10/2021 8:43:53 AM • Whirlpool... • Answered on Jun 10, 2021
Whirlpool WRT138TFYB00 removal of drip pan
Drip pans don't normally come off. They are part of the compressor top so the heat from the compressor is dissipated into the tray to evaporate the water.
6/9/2021 4:23:26 PM • Whirlpool... • Answered on Jun 09, 2021
Have a Whirlpool top freezer fridge. The freezer is getting ice build up from water build up. It also now leaks some of that water to the refridgerator now getting everything wet.
Could beDefrost heater failure.Defrost Timer failure.Blocked drain.The drain is the easiest to check and fix. There should be a pipe and a small water trap on the rear a little lower than the freezer compartment. Remove it and see if it is blocked.Heater are timer are hidden behind the panel at the rear of the freezer compartment.https://www.youtube.com/results?search_query=whirlpool+refrigerator+clogged+defrost+drain+tube+
5/23/2021 4:23:43 PM • Whirlpool... • Answered on May 23, 2021
2answers
I can't find the filter on my Whirlpool fridge, model # WRB322DMBM00
Hello Cynthia Gamez! Per the parts list for your specific model there is no water filter on this model Refrigerator. We do apologize for the inconvenience this may have caused. https://www.whirlpool.com/content/dam/global/documents/201401/parts-list-W10671574-RevA.pdf
5/19/2021 3:51:28 PM • Whirlpool... • Answered on May 19, 2021
2answers
Chemical smell in kitchen. is it coming from my brand new refrigerator?
the odors are normal for some new refrigerators,its due to the type of plastic used,let it cool and put coffee inside both compartments or baking soda as these 2 items will remove odors,after the odors gone continue to keep a box of baking soda in each compartment to control all food or plastic odors,this should help remove your odor problem
5/14/2021 5:01:07 PM • Whirlpool... • Answered on May 14, 2021
The strobe light on my whirlpool refrigerator (wrs331fddb) flickers when I open the door.
Strobe lights are designed to flicker. It's all in the description.
5/11/2021 12:30:23 PM • Whirlpool... • Answered on May 11, 2021
Whirlpool refrigerator WRT318FZDWOO not cooling after electrical plug it was plugged into went out
you need to call an electrician locally
5/7/2021 10:22:26 AM • Whirlpool... • Answered on May 07, 2021
User guide for whirlpool model WHKMD40 water dispenser
It is here
WHIRLPOOL WHKM-D40 USE AND CARE MANUAL Pdf ...
https://www.manualslib.com > ... > WHKM-D40
View and Download Whirlpool WHKM-D40 use and care manual online. Whirlpool Water Dispenser User Manual. WHKM-D40 water dispenser pdf manual ...
Whirlpool WHKM-D40 Manuals ' ManualsLib
https://www.manualslib.com > ... > Water Dispenser
Whirlpool WHKM-D40 Pdf User Manuals. View online or download Whirlpool WHKM-D40 Use And Care Manual.
4/24/2021 10:36:36 PM • Whirlpool... • Answered on Apr 24, 2021
Refrigerators Logo
8 questions posted
Top Whirlpool Refrigerators Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Refrigerators
Most Popular Question
condenser
  • Refrigerators
