20 Most Recent Desa International GWRP16 16,000BTU LP Gas Heater Questions & Answers
I bought a new Desa
Yes, click on the following link and it will take you to Master Distributors. They stock DESA/Vanguard parts. Sorry that you'll have to pay for something that was supposed to come standard with the heater. http://www.vanguardheaters.com/
Be sure you have your Model Number handy when ordering.
3/10/2011 1:38:33 AM • Desa... • Answered on Mar 10, 2011
I have a Glo-Warm "DESA GWRP16" LP wall heater.
sound like the reg is locking up turn off gas then turn on very slow see if you get gas flow , if not then you could try new reg
11/30/2010 12:33:42 AM • Desa... • Answered on Nov 30, 2010
The middle of the five upright ceramic tiles that house the flame puts off a bright yellow flame.
http://www.fixya.com/support/t26881969-vanguard_ventless_heater_won_t_shut_off Feb 7, 2018 - If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. ... Hi it is blue with a slight yellow tip ... at www.desatech.com , then go to "Wall Heaters" then click your model ... I fixed this by dismantling the fire and right next to the control knob ... Gas wall heaters vangaurd model VP2600C 10 answers Jan 31, 2014 SOLVED: I have a vanguard propane wall heater, 5 ... 2 answers Jan 6, 2010 More results from www.fixya.com
2/28/2019 7:18:56 PM • Desa... • Answered on Feb 28, 2019
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
2/19/2018 12:59:43 PM • Desa... • Answered on Feb 19, 2018
0answers
The pilot on my sunstar corcho wall heater won't stay lit
Try cleaning the gas tube with a pipe cleaner and insure the flame is in contact with the thermo coupling.
5/18/2014 9:45:44 PM • Desa... • Answered on May 18, 2014
0answers
0answers
I HAVE A DESA MODEL T36 NRA
I have same model, went to all parts.com and ordered pilot assembly for 105$ , has all in one kit. Part # 108084-02 easy instal Good luck
9/24/2013 8:56:59 PM • Desa... • Answered on Sep 24, 2013
0answers
Fireplace parts
Be the first to answer 9/19/2013 8:34:29 PM • Desa... • Posted on Sep 19, 2013Be the first to answer
0answers
Desa fireplaces
Be the first to answer 7/25/2013 2:13:49 AM • Desa... • Posted on Jul 25, 2013Be the first to answer
Why gas log fireplace releasing black soot
Logs are likely not placed properly on the burner. Option two is if they are a vented gas log soot is normal, but only on vented sets. Unvented Logs will be soot free. Soot is a sure sign of Carbon Monoxide. Install a detector if you do not have one.
2/10/2013 11:44:21 AM • Desa... • Answered on Feb 10, 2013
Desa International GWRP16 16,000BTU LP Gas Heater Logo
Popular Tags
6 questions posted
Top Desa International Heating & Cooling Experts
Paul Carew
john h
Jay Finke
Jay Finke
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Desa International Heating & Cooling
Most Popular Question
glo warm desa gwrp16 lp wall heater
  • Heating & Cooling
