20 Most Recent Whirlpool GT4175SPS Stainless Steel 1200 Watts Microwave Oven Questions & Answers
Most likely the power supply has to be replaced; but it could be the safety switch too. Do you have any experience or knowledge in using meters and troubleshooting electronics? If not and you want to repair the microwave- send it out to a qualified/ certified microwave repair shop. Or else buy a new one. Best regards ~
Whirlpool... • Answered on Mar 13, 2014
hi,
As you mensioned the Magnetron or the capacitor of the oven is short. If the magnetron or the capacitor is short then the transformer driving the magnetron will get over heated because of the over current drain. It will finally result in failure of the mains fuse inside the oven. You have to check the fuse first. If its faulty then change the same with anew one. If the fuse again blews the you have to replace the manetron and the capacitor. The magnetron and the capacitor will look like on in the picture. Magnetron in the microwave oven produce the microwaves which heats the food.
ok
Whirlpool... • Answered on Sep 09, 2011
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
Whirlpool... • Answered on May 03, 2011
The microwaves are produced by a MAGNETRON. Everything else can work, but if that does not, then there is no heat added to the food. Unfortunately it is the most expensive part of the microwave and has nothing you can really work on.
Hope this helps.
Whirlpool... • Answered on Apr 29, 2011
If the motor is not turning on then the motor is getting short and it has to be replaced.And for no heating, the magnetron is the problem.If the magnetron gets faulty, then unit will not heat. Click this link to see and order magnetron:--- http://www.appliancepartspros.com/part_details.aspx?part_id=4247306 ------------ Click this link to see turn table motor and order the motor:--- http://www.appliancepartspros.com/part_details.aspx?part_id=4308692 ---------------- Click this link below and see part number 11 its turn table motor:--- http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132508&diagram_id=28169834#d28169834 ---------------- Click this link and see part number 13 its magnetron:--- http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132508&diagram_id=28155009#d28155009 ----------- To get motor replacing procedure.Click the link below:--- http://technoanswers.blogspot.com/2011/04/how-to-replace-turn-table-motor-on.html -------------- This should help.Keep updated.Thanks.Helpmech.
Whirlpool... • Answered on Apr 06, 2011
Basic
Microwave Oven Troubleshooting Tips
heatman101
Whirlpool... • Answered on Jan 16, 2011
you must !!!!!!!!!! discharge the capacitor first or it will kill you !!!!!!!!! use a discharge wand then cut out old diode and resolder new one ..
ps tell me why are you replacing the power diode in 15 yrs working with microwaves ibe never seen one blow
Whirlpool... • Answered on Dec 02, 2010
Whirlpool GT4175SPS Stainless Steel 1200 Watts Microwave Oven Logo
47 questions posted
Top Whirlpool Microwave Ovens Experts
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Sheldon Dedek
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
turntable not turning
  • Microwave Ovens
