20 Most Recent Bose 3 2 1 Series I DVD Home Entertainment System , Retail System Questions & Answers
http://worldwide.bose.com/productsupport/en_us/assets/pdf/guides/321/321_series1/en/owg_en_321_series1.pdf
Bose 3 2 1... | Answered on Apr 14, 2011
Please let us know the website link of the online store where you placed the order.
I tried to search for the information related to "Canada's Entertainment Shop" and from the reports available on the internet, it appears that the website might not be genuine.
Kindly reply with the details. Thanks for using FixYa.
Bose 3 2 1... | Answered on Apr 10, 2011
check that the input source it set to aux on the bose. to check it is on turn the volume up a bit and touch the contact end where you plug into the source. it should gently hum when you touch the connectors then you know that the input is live on the bose. i take it you have it switched on lol
Bose 3 2 1... | Answered on Apr 09, 2011
Usually with DVD players there's a tiny hole in the front of the DVD slot that's meant for unsticking jams.
http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html
Bose 3 2 1... | Answered on Mar 07, 2011
Check the connections to the centre speaker which is where the actors voices come from.
Bose 3 2 1... | Answered on Jan 29, 2011
To connect the iPod to the system correctly, follow this simple procedure:
  1. Plug the iPod AV adapter into the charging port on the bottom of the device. This is the same port you plug the charger or USB cable into. The other side of the adapter will have three RCA ports. The yellow port you are not going to use because this controls the video portion of the iPod.
  2. Plug the red and white RCA cables into the "Audio In" ports on the backside of the Bose GS Series II interface module. This is a small piece of equipment used to control the two speakers and the subwoofer.
  3. Power on the Bose GS Series II and your Apple iPod. Turn up the volume to the speaker system using the provided remote control. You can now play the music you want to listen to by selecting it from the menu of your iPod.
If you want to play music you can use your ipod nano, but if you want to play video you need to use ipod 4th and 5th generation. Here is a link to the complete manual for the advanced remote control: http://www.devicemanuals.com/guide/Home%20Entertainment/BOSE/BOSE-3%C2%B72%C2%B71-advanced-remote-control-Owner's-TnpBMk1EYz.html Good luck and happy holidays!
Bose 3 2 1... | Answered on Dec 21, 2010
My cable missing and how I can made the new one.
Bose 3 2 1... | Answered on Oct 09, 2010
You can connect your iPod to your Bose V30 using an ipod dock, or simply with a mini-jack (headphone jack) to RCA cable plugged into your V30's Audio-In ports.
I hope that helps.
__________________________________________
Download Bose LifeStyle V20 User Manual
Bose 3 2 1... | Answered on Jul 05, 2010
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
Bose 3 2 1... | Answered on Apr 19, 2010
Hello. Push input on your tv remote and run through the menu until you find the setting you had used previously to get the color and sound.
Regards, Joe
Bose 3 2 1... | Answered on Dec 22, 2009
[email protected] email me if you still want to buy Philips iPod docking station. I just came across one in a box of misc. electronics I bought at an auction house in Phoenix, AZ. I can use eBay and list it as a private auction. I don't have anyway to test it. I would refund $ it did not work.
Bose 3 2 1... | Answered on Sep 23, 2009
normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
it may also help if you can keep the bose 321 vertical.
Bose 3 2 1... | Answered on May 30, 2009
make sure it's compatable with the system, there are many different formatted discs out now and all are not working well, it's not by chance a blu ray disc is it?
Bose 3 2 1... | Answered on Mar 22, 2009
Look at the back of your 3-2-1 to see if the auxillary is a single or dual output. You will need that information when you go to Radio Shack, or you can also get at the Apple store, a connector from Gigaware that connects to the ipod. It was only $15-$20,
Bose 3 2 1... | Answered on Mar 21, 2009
it must be the lens....
try cleaning it with one of those "cleaning cds" that have small brushes on their surface...
Bose 3 2 1... | Answered on Mar 17, 2009
Check your settings - video format. It should be NTSC for USA standard. If it is set to European (PAL) it will be in black & white. Hope this helps.
Bose 3 2 1 Series I DVD Home Entertainment System , Retail System Logo
36 questions posted
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
connect ipod bose lifestyle v30
  • Audio Players & Recorders
