20 Most Recent
Marvin Quartz Radiant Heater Questions & Answers
Loud buzzing after heating up
the buzzing is normal. there is an element inside the quartz tube much like a filament in a light bulb. as this heats up it starts to move. where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Locating replacement quartz bulbs for comfort zone heater
To locate replacement quartz bulbs for your Comfort Zone heater, you can try the following steps:
- Check the manual: Your Comfort Zone heater should have come with a manual that includes information on replacement parts, including the type of bulbs needed. Check the manual to see if it specifies the type of quartz bulbs that are compatible with your heater.
- Check the label: Look for a label or sticker on the heater that lists the make and model number. This information can help you find the correct replacement bulbs.
- Contact the manufacturer: Comfort Zone is the manufacturer of the heater, so you can try contacting their customer service department to ask for assistance in finding replacement bulbs. They may be able to provide you with the specific bulbs you need, or they may direct you to an authorized dealer or retailer.
- Search online: You can also search online for replacement quartz bulbs that are compatible with your Comfort Zone heater. Try searching for the make and model number of your heater, along with the keywords "quartz bulbs" or "replacement bulbs."
It's important to note that if the halogen lamp is also not coming on, there may be an issue with the heater's electrical system. In this case, it may be best to contact a professional electrician or appliance repair technician to diagnose and fix the issue.
Is it safe to plug a 1500 watt Marvin quartz
You had a low end cheap receptacle more than likely or possibly a loose wire on the receptacle. You should have #12 wire fed from a 20 amp breaker and a 20 amp spec grade receptacle.
I am a licensed electrician with 30 years experience. IBEW LU #479 Beaumont TX.
